- Mar 8, 2008
The arc of a stroke is comprised of two things: the path and presentation. It's as if the scythe were mounted on a lazy Susan on top of a rail road cart, with the track being the path and the presentation being how the scythe is oriented (by pivoting the lazy Susan) relative to that path. In the above image, the red circle (partially visible) represents the minimum radius of a stroke, in which the right hand is the pivot and no motion along a path is made. The curve of the edge is set equal to that arc, and so at that stroke the blade would be in 100% slicing action, and so technically wouldn't cut anything, but instead skirt perfectly around the target. The two green circles (partially visible) represent radii centered on the left hand and extended to the toe and heel of the blade, which describes the depth of the swath, but you can see that increasing the radius of the stroke has, without at all changing the hang of the blade on the snath, closed the presentation to the stroke, causing the angle of the toe relative to the stroke's radius to become greater than 90° (the fuchsia angle) and therefore the spine is leading instead of the edge. The blade will not cut, then, until the blade's presentation is brought to an angle of 90° or less relative to the stroke.
Regardless of the shape of the path, this rule must be obeyed, or the spine will precede the edge in the stroke.
