- Mar 8, 2008
Just received my first batch of custom stamped box wrenches for Seymour snaths (all current models.) The large end is sized for the nut of the loop bolt and the small end is sized for the retaining bolt of the heel plate. Nice and flat so it slips in a pocket unobtrusively, and made for us in the USA out of plated, heat treated steel. They'll only be about $1.50 and I'll be getting them up on the site tomorrow if things go to plan. Wish I had one of these things years ago--it would have made field adjustments a lot easier than carrying around a typical wrench
is one side 5/8"? i might get one of those instead of having a ratchet in my pocket. why a ratchet? i like using a ratchet more than an adjustable wrench
Considering original snathwrenches are scarce, hope you do well selling those.
Looks like a Derby & Ball No.50 snath that was contracted by a hardware store, as it doesn't have their usual branded label. Do you have any photographs of the bends in the blade? I can't see anything clearly amiss in the photos above.
Good looking rig.
Thats cool Kelly blade with ”WPA” stamped. Tang angle set also. Its prior user knew how to set up a scythe.
Any background info on that wpa blade? I knew about saws, axes, pickaxes stamped marked wpa.
When I think WPA terms new infrastructure, improvements come to mind(construction tools marked wpa make sense). Just wonder what project did it come fromI have not yet looked into the stamp and markings but will post what I learn when I do![]()
