Who still carries a Case Knife?
I'm not sure I completely follow, although I share your love of the 6332. I can't see much difference in the frame shape of either version of the 32 aside from the length. I didn't realize they were considered a reverse gunstock actually and just thought of it as a serpentine with square bolsters. I'll have to do some more learnin' about that type of pattern .
It almost seems like the sheepfoot seems more proud on the 63032 because the clip sits a tad higher on the 6332 because of its additional size. So the clip sits lower on the 032 which makes the sheepsfoot appear higher. Either way, I like the older pattern a lot more.
Tomorrow, I'll try to post my 32 next to my 18. The 18 is a much more traditional serpentine frame. The 32 definitely has serpentine-like qualities. But, it also has more of a "hump" just offset from the center pin. I will admit its not as extreme of a gunstock as most. And, I do think case nailed the subtlety on the 32 pattern. One of the reasons it's becoming a favorite of mine.
Fwiw, I may have the "reverse gunstock" term confused. But, I believe a GEC 76 is a regular gunstock and Case's 32 pattern is a reverse gunstock. I'm seeking clarification on this myself.
What an excellent observation on the clip shape though! The sheepsfoot sitting lower might be an optical illusion of sorts caused by the bigger clip.
I do find these comparisons interesting, especially considering the minor, subtle differences, which probably weren't apparent to the average customer at the time.
6318 for today’s EDC. OH
Many thanks, it's unusual in having a Spear master and the sunk-joints make it very pocket friendly. It's a CASE 63046 Humpback Stockman in pocket-worn Harvest Orange Bone, 3 5/8" this from 2009 and it came in a very nice tin. I think this pattern is currently discontinued but it came in a number of scales including very tidy Red Sawn Bone and 6.5 Bonestag. I gave the blades a mild brushed treatment as I prefer it, just wish CASE would do ALL their stainless blades in it. Great snap and fit on this one.
Good luck in locating one. They also did a 2 blade Humpback Whittler on the same frame.
Thanks, Will
Thanks! These are really nice and a great size.
,,,Mike in Canada
My understanding is that all bone covers had pinned shields up until the late 70s. I've seen some state that the first unpinned shields on bone covers appeared in 1978 and by 1980 all shields were glued and not pinned. Take this for what it is worth 😝 But, your 67 is most certainly pinned if it is bone.
Did I say "67"? OOPS! I meant "77," but that that would still be consistent with what you've said here. I took another careful look and I'm pretty sure that this one is pinned. That mistake kind of messed up the whole point I was trying to make, which was that my 32 pattern is one year newer than Dan1892 Dan1892 's and is (apparently) pinned. Oh, well. :(
Rufus1949 Rufus1949 Many thanks, I actually tea dyed that Collab....took some nerve :D:eek:
Thanks for showing the Big Red CASE open, didn't realize it was a Stockman, thought it was their Large Penknife.
Ahhh, I should've realized that when you said 67 and not 65-69 😝 I found that sometimes you can see the pins from the outside, but looking inside the blade well at the liners often allows you to identify if the shield is pinned or not more easily.
As promised here is an old 18 pattern with an old 32. Hopefully, the "gunstock" portion of the 32 pattern is more evident. You'll notice quite a hard line or "hump" above the C in CASE on the mark side and the same near the end of the pen blade on the pile side. You'll also notice that the turkish style clip on the 18 pattern gives the appearance of a more "exposed" sheepsfoot:
My understanding is that the GEC 76 is a true regular gunstock pattern. And that, for example, the Case 6232 is a reverse gunstock pattern. The GEC gunstock is certainly more pronounced and the Case more subtle. But, both are there if you look closely enough. And, if you open the main blade of the GEC and point it at someone, the "gunstock" will be closest to you. If you open the main blade of the Case 6232 and point it at someone, the "gunstock" will be closest to them. I believe this is where the term "reverse gunstock" came to be. Some pictures for comparison:
Here's another comparison of an older 18, a newer 18, and an older 32 with all blades open except the sheepsfoot. The 18's, like most of my stockmans, have a point outside of the blade well. This is not an issue during normal use. The 32 sits nicely inside of the bladewell:
The more I look at and think about the 32 and 18 patterns, the more I think case just knocked it out of the park with the older 32 pattern and this has nothing to do with it being a gunstock pattern. In theory, the 18 could sit the pen and sheepsfoot blades lower than they are currently, but they don't. Not particularly sure why. Usually, you don't sit a blade lower in the blade well because you want the nail nick to be accessible and you don't want blade rap. There's plenty of room for the nail nick on the 18 pattern. So, I can only assume it rides as high as it does to prevent blade rap. This causes the sheepsfoot to ride higher because the nail nick needs to be accessible. One thing I do believe can be attributed to the gunstock pattern is how nice the 32 pattern feels in hand when using the clip and how nice it looks aesthetically. I think the extra "beef" (ie; the gunstock) around the sheepsfoot (because it the gunstock is reversed) makes it just a little bit more comfortable. And the larger clip compliments the sheepsfoot well, making for nice lines.
I took a closer look at all of my older Case's and do see that they are pinned. It was tough to see on the 32 but I eventually spotted it. I was looking at the inside of the liner around the middle part of the shield, but it looks like the pin is on the end of the shield (right side as you look at it). All of my knives from the 70s show the pin in the same place but my trapper from 1985 doesn't. Sorry for the confusion.
Edit: Looks like there are 2 pins in the shield. One on either end. I'm going blind I think...
hahaah yea, while I do believe some manufactures leveraged a single pin near the middle of the shield, I believe that case always had 2 pins; one on each end of the shield.
Got a Kentucky bluegrass jig bone trapper today. Not sure how I feel about it. Isn’t nearly as dark as the Case pic….
It is much lighter in the show side with hints of blue
And on the back there is quite a lot of blue…
Not sure I like it. Otherwise the fit and finish are great.
I think this is really beautiful. So much so that I looked it up online. The ones for sale don’t really show true pictures, only stock. I’mm not sure they would be as nice as your specimen.
I’m starting to agree with you. It’s grown on me. I’ve decided to keep it. It was a birthday gift from my family as well. It’s also flawless otherwise, which can be challenging to get with Case unfortunately. No gapping, blades are centered, etc. In true knife nut fashion I’ll probably buy a pocket worn Bermuda green one now, lol.
I think it looks great. I have an old appaloosa barlow. One side is brown, the other is like this crazy lighter appaloosa coloring. When something is handmade...I expect good craftsmanship, but I am cool with unique color variations and such.
Thanks, Will
Thanks Will! Many times I see these older patterns and wonder why they were removed from the production cycle. Hopefully the "Vault" will open and more will be available again.
,,,Mike in Canada
Awesome. I‘m glad it grew on you. I’m trying to figure out if I want to roll the dice one in that color/pattern. Found a single blade trapper online.
