right to you both
and remembering I'll need the blade blank profiled but not tapered >:first:,
to place the holes in it,
OK, a Grey < the Color< aria there must be some questions?
I'd like to have a blank of the blade to copy the holes to and
use as a pattern to profile the jade (for Roger) to where as it's going to be relieved as the handle is to be.
I can make the pattern but it will have to be tapered the same as the Blade to work.
as to say
I'll receive the blank and the blade
put the alianment/hold down/pin holes in both ( recording the holes from my DRO)
I'll relieve the pattern for the handle material profiling
(for Roger or I to do.)
then send the both to Dave to have them tapered exactly the same,
then them being sent back to me to fit the handle materials,
Roger prepares the jade to length and the end tapers
for the dovetails with the centers filled and sized,
so we're looking at
1 blade being profiled, sized and sent to me,
before tapering and any filing.
2 a blade blank profiled the same as the blade to use as a
pattern to be used for the relief and as the pattern/template
for the
Jade and Mokume profiling later by Roger or Myself.
2 Roger works up the jade length, does the dove tail
tapers on it and fills the centers
sizes the thickness then sends them to me,
(before final profiling.)
3 I will place the holes where need be in the blade tang
and in the blank pattern,
4 I'll relieve the pattern for the handle material profiling
5 I'll send the Blade and the pattern to Dave for the tapering
and grind on the blade then they come back to me.
6 off to Roger for the heat treat
7 then off to Steve, I believe to do the finish on the blade
before the etch..
I believe Roger is doing the shaping of the handle.
being a take apart the handle should be shaped on the pattern
while the etching is being done to the blade.
then off to the others for their parts in it.
OK guys, is this close so far? or am I way off?
