- Aug 3, 2008
Nathan I had one disk that was out of balance but was only slightly noticeable at high rpms but more noticeable when running slow. This in the end it caused the motor bearings to fail prematurely at less then two year. I had four steel disks form the same supplier and only this one had this problem. What was difference in this one I don't know. These where made from mild steel(plenty though) and from what I can tell where made in the same method as you described. The disk had .5* and it was more then enough to keep your stock for touching the other side of the disk. Price was about $90 a few years ago if that helps.
One thing I would recommend is a light press fit for the shaft.
Brett
Brett
