Blop said:
It takes mail forever to reach me, it is the cold, I think it slows time.
JDBLADE said:
To give an example if you read Cliff Stamps review of the Blackjack Small he in my view went beyond the parameters of the knife eg the knife lost 1/8" of the tip working on a coconut - now how does that assist in the evaluation...
It allows the users to bound the scope of work without risking the knife themselves. Lots of people don't have the experience to make such judgements. All of the knives I get for reviews are used to failure for two reasons :
1) it prevents me from biasing the review because I like the knife and want to keep it
2) it prevents me from looking at a lot of junk knives because people who hype knives tend to really run from seeing what their knives can't do, people with solid knives don't worry about what the knife can't do because they never promote that anyway, all they say is yeah, it can't do that, buy something else if you want a knife to do that, but look at all the stuff it can do well
So when I take a Blackjack small I will use it for everything that I can think on that the knife should be used for, the review contains a massive amount of work besides the one line you mentioned (it is also still in progress). Then when all that is done I will do work showing what the knife does not do well, where it fails, where you would want a different kind of knife. The coconut tip snap was unexpected also, the tip didn't flex at all, just cracked. It also isn't that difficult to do, just baton the edge into it, ork around, then force the entire blade in and pop it open, you can do it with a SAK.
For example if I had to compare a splitting axe, maul, and super wedge (20+ lsb triangular heads), I would take them from very light to very heavy wood and show where each excells and where each fails badly. This helps give the user some idea of what is a decent choice for them. If you wanted a knife for significant prying/digging in woods then the Black Jack Small probably isn't a good choice, however if you want a nice light cutting knife with an effecient edge profile which is easy to sharpen, nice ergonomics and fairly versatile, then it is a solid choice.
As for the folder thing, yeah, Strider was tested and it did well, and again, the known weakness of liners and integrals are torques not vertical and horiznotal loads. Joe has described this problem for years, I have seen it as early as '98 and I am sure he was aware of it before then.
Yes I have not used a Strider folder, because the maker indicated that the design of the Buck/Strider had a known weakness to torques and has never stated that his own folders are any different. Why would I then go out and buy one, that makes no sense. There are lots of locks which don't have that problem, I'll buy them instead.
If Mick actually stated that his folders don't have this weaknes to torques and are actually stronger and more durable than the Chinook I used recently then I would be interested.
And yeah if you promote your knife by throwing it around, beating it into concrete, hacking into metal, I do thin it is fair game for the consumer to do this and it should be covered under the warrenty without any reservations. if you don't want people to do it - then do NOT promote the knife by doing it.
Now of course if you break it in the demo, then that is different. However if at the end of the demo the knife is fine and you use this to sell "See how tough my blades are, they did all this without a scratch!", then that is a different matter. A knife should be able to do what it is promoted to do. It is abuse when you exceed this, and unfair when you expect the warrenty to cover it.
For example, lots of makers do flex tests, showing how far their blades can bend. If a user bends it and it breaks at the same point then it isn't reasonable to expect a replacement. The knife did what it was supposed to do. However if you promote breaks at 50, and it breaks at 25 then you better make good because the knfie did NOT perform as advertized.
-Cliff
