- Jan 15, 2015
If we imagine two ideal hones, one having 5 micron abrasive grit and the other having 10 micron grit, with all else equal, we could expect the dimensions of the metal swarf from the 10 micron hone will be twice as thick and twice as wide as those from the 5 micron hone. For the same distance traveled, the length of those swarf particles would be the same for both hones. Therefore, the volume of the individual swarf particles should be 4 times larger for the 10 micron hone than for the 5 micron hone.
It may also be reasonable to assume that the number of swarf particles produced will be proportional to the density of grit particles in each hone. If we consider the following drawing, where the red circles represent the 5 micron particles and the blue circles represent the 10 micron particles, we see that there can be four times as many 5 micron particles as 10 micron particles in the same area.
Combining these two assumptions, the 10 micron hone removes one quarter as many metal particles as the 5 micron hone, but the particles will be four times the volume. In other words, shouldn't we expect the material removal rate to be the same for both???
