The obvious question that follows is why use a progression of grits if the coarser stones aren't faster?
If I can remove metal at the same rate with a 4k as I can with a 1k, why bother with the 1k and 2k?
You are correct about pressure, but what if we use the same pressure?
I'm just suggesting a simple model to point out that all else equal (including pressure) the removal rate should be the same for the two hones.
I wonder if the swarf doesn't limit the downward travel of the item being abraded after a certain amount of movement - since the abrasive particles stick up less, there's less room for swarf before it might bind up and limit the depth of cut. I need to do some thinking on this one.
(Gahlin, R. & Jacobson, S. (1999). The particle size effect in abrasion studied by controlled
abrasive surfaces. Wear, Vol. 224, No. 1, pp. 118-125).
The unit pressure is going to be tremendously increased for the coarse stone. The absolute tip of each contact point shouldn't be a whole lot larger - determined by the abrasive type and condition.
In your 5 micron and 10 micron abrasive, lets imagine that's the amount the abrasive stands proud. that would make them a 100 micron and 50 micron abrasive chunk. These hones are not all that far apart, the difference between 120 and 360 grit or so. If you compare a 100 micron and 20 micron now you have a much larger difference. Now 10 and 2 micron abrasive depth, a difference of 5x the unit pressure on each available abrasive point for the same amount of applied force.
You have to factor in not only increased unit pressure but dramatically increased chip clearance. The rougher stone can accommodate greater volume of swarf.
Another factor depending on abrasive is the coarse hone due to much greater unit pressure will experience break down at a much faster rate, the finer abrasive will experience greater glazing effect. Increased pressure will only accelerate the plugging of the stone with nowhere for the swarf and broken abrasive to go.
Given what ToddS is asking... I don't think pressure (or even swarf) needs to be factored in. (Don't misunderstand, I know in actual sharpening it does). I think he's just asking why a 5m stone won't work as fast as a 10m... everything else being equal. I know realistically, pressure / swarf / etc. all contribute, but to the original question not so much... the way I read it anyway.
look at post 17 againPressure is everything.
Even if you switched the conversation to two 800 grit surfaces, one with an open coat and one with a closed coat, the open coat (for as long as the abrasives stay intact) will cut faster - remove more steel per unit of infeed time. And this with the same approx abrasive depth potential and a smaller number of points per.
You might guess I have a reason for asking this question. I measured the removal rate for a piece of hardened carbon steel (approximately 1cm^2) on a variety of hones with the same downward force (approximately 500g), and found that the removal rate was essentially the same for the Shapton Pro 320, Chosera 1k, Shapton Glass 2k and Shapton Glass 4k. (The rate did drop off with the 8k and 16k Shapton Glass stones). I'm not claiming this was a systematic or highly controlled study, but it does lead me to the question of why do we generally assume coarse hones are faster than fine hones.
Pressure is everything....
Still and all, the larger chip from the coarse abrasive has a much wider surface area at its gouge trough. So much deeper and much wider than a collection of smaller abrasives. Back to the 3D model with its surface area to volume relationship. Applied to chip removal that explains plenty.
http://www.bladeforums.com/forums/showthread.php/1449226-(Why)-Are-Coarse-hones-faster-than-Fine-hones?p=16681211#post16681211
They are showing that if the abrasives are sharp, there will be no difference in the removal rate for open and closed coat.
I think you'd have to give more of the specifics of your experiment, because now you have introduced other factors into the equation besides simply the abrasive size.
There is an optimal range of volume displacement (VD / feed rate) by bit configuration per material. In uniform distribution in an area, bit density is square order. Whereas VD is cubic order. In a meaningful comparison, pressure/feed-rate should be within optimal range per bit size. So e.g. 320 to 5K shapton rate of removal are about the same for 500gr, which could mean 500gr still within 5K shapton upper optimal limit vd rate and at the same time it's at the lower limit of 320grit shapton. Now, with 10kg pressure - 5K shapton will not cut well at all (due to grit detachment + loading). A needle is not a jack hammer bit and vice versa.
I think, just looking at your picture, that other factors now come into play. For example swarf could affect it... might try repeating it under running water where the stone is continually flushed?
I also thought a bit more about pressure... while one route (that you took) was to keep the pressure the same... the other route (that I think Heavyhanded meant, in part anyway), is finding the optimal pressure that the stone works at? So, for example, you could find a set pressure where both stones cut the same... for example very light pressure wouldn't take advantage of the "cutting ability" of the coarse stone, so both would appear to be approximately the same. But add a little pressure and the cutting of the coarse stone could increase dramatically, with little affect on the finer stone.
