- Mar 10, 2002
maybe we could start a special fund for those guys?
You're so thoughtful.maybe we could start a special fund for those guys?
two reasons: materials and labor.
I've purchases sheaths and I've made several. I've used moderately ghetto equipment and EXTREMELY ghetto equipment. some turned out okay, others looked like I ran over it with my car a couple of times (not far from the truth).
The material cost:
12x12 .08 black kydex sheet - 5.00
small tek-lock belt loop - 10.00
mounting screws/chicago screws/foam washers (10)- 6.00
Pack of rivets (100)- 10.00
tools required:
rivet flare - 2.00-100.00 (I have a 1 ton arbor press and riven flare bit from harbor freight that was about 50$)
closed cell foam - 9.00
drill press or dremel - 25.00-100.00
hacksaw/sander/sandpaper - 10.00-100.00 depending how ghetto you want to be
c-clamps - 10.00
channel iron or thick pieces of wood - 0.00-20.00
so. at the absolute cheapest to make your own sheath, assuming you have all the tools required, your minimum cost for 2 sheaths (12x12 kydex sheath) is 31$. This is assuming your going to work for free. You can stretch the cost out a little bit by using the 100 rivets and the other chicago screws for your next sheath, but it's only going to drop the price by a few dollars. your still looking at around 20$+ in raw materials unless you can buy in bulk. If you need to buy the bare necessary tools your looking at a minimum of 40$. You NEED something to cut holes in the kydex, cut the kydex, flare the rivets, and press the kydex into shape. that 40$ is even assuming your going to do it as absolutely ghetto as possible:
Your going to use your dremel to do everything. You're not even going to use rivets, your going to drill the holes with your dremel and use bolts and nuts to secure it, your not going to use a tek-lock your going to get a piece of belt leather and dremel holes into it. Your going to cut the kydex to shape with your dremel and your going to use 2 pieces of salvaged 2x4's with two c-clamps to press the foam against the kydex. your still looking at 9$ foam, 20$ dremel, and 10$ c-clamps.
Then there is labor. Lets assume the person wants to make a modest 10$ an hour, which is just above minimum wage here in california. It takes me at least 45 minutes to get a sheath from parts to usable, and an hour and a half if I'm trying to make it look nice, assuming all goes well. It's pretty hard to get things to work right when your jerry rigging channel iron and multiple c-clamps by yourself.
Add 15$ to your 31$ materials cost and you now have a 46$ sheath or [15+15+31]/2 = 30.50$ per sheath for two sheaths. Nothing is free. Nothing worth having is easy. If you want to make your own sheaths you can cut costs in the long run, but you probably won't get the quality and consistency as a maker purchased sheath and you'll have to spend the initial capital to get the equipment, unless you have your own shop that's already set up for that type of work.
This was a great write-up. Haha how long did this take you?
1)If you knew it was coming then that's called trolling.
2) Hand made versus mass produced
3) This belongs in whine and cheese
4) Banned smiley
I asked a similar question as yours a while back, 230, and was greeted with the same mix of thoughtful responses and people bashing me for being a cheapskate.
Your question was "Why are sheaths so expensive". YOU went on to compare them to your mass produced pistol holsters. I would say I answered your question pretty well though not as in depth as others.
Look up what trolling means and I believe I was again correct.
If the same question was poised to me in real life the answer may be different or the same depending on the context it was presented in.
You are not the first, last or only to accuse me of being anti-social so no big deal.
I do apologize for the fourth comment though. I was wrong to use it.
Bottom line is if I buy a $250+ knife I'm not going to worry too much about spending the extra dollars on a good sheath for it. Kind of like putting a high end Wilson 1911 in a Uncle Mike holster.
YMMV
Bob
I stand by what I said. Extraneous and inflammatory remarks seem to fit especially when comparing custom to mass produced. Intent on the internet is pretty tough to convey at best.Well, I did look up the definition of trolling, and it's exactly how I understood it. From Wiki:
"In Internet slang, a troll is someone who posts inflammatory, extraneous, or off-topic messages in an online community, such as an online discussion forum, chat room or blog, with the primary intent of provoking other users into an emotional response[1] or of otherwise disrupting normal on-topic discussion.[2]"
My post does not fit the bill, sorry. I posted wondering why they're so expensive, and got my answers from a few helpful people. I suggested there should be a cheaper alternative, and also got my answers. There was nothing inflammatory about my post, however yours was filled with anger and aggravation. You then go on to say how you answered my question. No, you simply reiterated the fact that has been stated several times already, custom vs production. You simply threw that in there so you could have an excuse to vent your anger in your life in my post.
As for your analogy about putting a wilson combat in a uncle mikes sheath, I get it. But that said, I'm also putting my 2k + ed brown in a 60 dollar holster that works perfectly. Soon I'll be putting a knife that cost 10% of what my brown costs in a sheath costing similar. No I don't expect to pay only 10% of what my holster costs, but yes it gets frustrating.
A lot of you guys are made of money, I can't afford to just buy endless amounts of knives and guns. I'm a middle class guy, making pretty decent money, but I can't afford to go to a knife show and leave with 20 blades. Buying a knife for 600 dollars is a big purchase for me, that's my truck payment. I'm not single, I can't just buy whatever I want anymore, so it sucks to spend a fortune, then spend even more to be able to use the knife I spent a fortune on. I have no interest in buying knives and throwing them in a drawer, i'll never own a safe queen so every knife I buy will need a sheath so I can get the most of it. I plan to own a bunch of Busse knives, so yes, in the end i'll be spending a small fortune on things needed to make my knife that cost a fortune work.
There is really no need to call anyone who posts anything you don't agree with a troll, I think we may all have different definitions of inflammatory, because your post was a hell of a lot more inflammatory than mine. If you want to troll hunt, do it somewhere else, not in my thread.
just like i bought several green river sheaths at blade for a ultra low price and they fit the busse knives perfect...
