Someone needs to educate themselves on what tolerances are- To know that anyone has tighter tolerances would have me believe that you have the blueprints in front of you and can measure the deviation from nominal.
The average person cannot do this..you may be able to FEEL it with how well something fits together and in some cases see it. Knowing it is something entirely different.
Anyone can have tight tolerances on almost anything but it only matters if those tolerances are applied in the right areas to control the assembly. I can have a tight tolerance on a lanyard bead but in the end, what the hell does that do for the assembly as a whole?
Will you feel ±.0001 on the diameter, inner diameter and thickness of a lanyard bead? Will it be more visually appealing or provide any other function? Will you know the difference from joe-blow's bead? Eh..not likely.
I have a few years being a machinist, like
@Officer's Match and it's pretty obvious when someone talks without knowledge on this subject.
