CSF,
I'm a steel simpleton and I'm sure one of the better experts will jump in and correct me but 2 things jump out about your rankings.
First, the lists are something like rankings of caffeinated morning drinks or brewed evening drinks. Better to separate out tea from coffee and compare them or beers ales and compare them. My simplistic view of steels is the tea/coffee or beer/ale split is among course grained steels and fine grained steels.
Fine Grained: carbon, 440A, 12C27, 420HC, Aus 8
Course Grained: 440C, A2, D2, 13C26
Second issue I have with your listing is that at it sweeps away differences in the heat treat which is done by the knife maker. It's like talking about Italian roast coffee. Really need to talk about Starbucks vs Peets vs Vermont Coffee Roasters. For example, Case takes their 420HC to about 56c and Buck takes theirs to about 58Rc. They feel very different. Old Bucks used 440C at 58/59Rc. One reason some old timers didn't like Bucks 440C is that it was too hard and abrasion resistant to sharpen with old traditional stones.
Third issue (did I say 2?) is blade geometry. Subtle, minor changes in blade geometry can really affect perceived "edge retention". Very thin blades like Victorinox SAKs or many of Bucks very thin hollow grinds will continue to cut regardless of the sharpness of the apex. Another reason why some old timers didn't like some Buck 440C is that back in the day, Buck ground their blades with a swell just above the cutting edge for more strength but it made it harder to sharpen and it took away from pure slicing ability.
In my limited experience, course and fine grained steels dull differently. Fine grained steels seem to make fine shavings better than my 440C blades which isn't surprising since they take finer edges. But 440C will keep cutting vegetables longer as it maintains a "toothy" edge, which course grained steels are known for. Fine grained steels round out or roll where as course grained steels chip.
I'm a bit surprised that you've found 1095 better than 440C in terms of edge retention. I think most people equate edge retention with abrasion resistance and, all things like edge geometry and heat treatment equal, course grained steels are more abrasion resistant.
I think you're right in your basic assertion that 440C shouldn't be hated. Far from it. It's a steel of a certain kind and steels of that kind are good at certain things. I'll leave it to others discuss the finer points of different course grained steels. But I would suggest starting there. Compare 440C to other course grained steels and keep an eye on hardness and geometry.
My only point is that 440c maybe outdated compared to today's newer blade steels but, it still makes the cut.![]()
CSF,
Ale is a type of beer. Just like lager, pilsener, stout, porter, india pale ale, tripel, etc. Beer encompasses many styles. All ale is beer. All beer is not ale.
13c26 is a fine grained steel.
Steels can dull by blunting, fracture, and other methods.
Performance is more complex than trying to categorize steels as fine grained or coarse grained.
I'm always amused when folks point to the work of pioneers like Hibben and Loveless and Moran as "proof" that a certain steel from 40 or 60 years ago is "still good enough". That completely misses the point of why those men were true pioneers! Those cats were often scoffed at, even ridiculed in their day for seeking out new alloys and techniques. Loveless in particular walked away from 440C in the 70's and continued to work on and with newer alloys nearly until his death. Where would we be today if they hadn't done their research and experimentation, and had simply gone on following the status quo?
Correct. The chemistry behind 440C is sound, and yes, it most certainly was considered a "hot new super steel" several decades ago. If a person likes big clumps of carbides, that's fine. When a maker like Laurence has sourced good quality steel and employs optimum HT, it will probably surpass any reasonable person's needs. On the other hand there are still some makers and obviously manus who merely shop around for the cheapest price and use the first HT "recipe" they stumble across... we know where that leads...
Unfortunately, numbers on a datasheet don't mean a whole lot unless you actually know and trust the mill... and the rolling plant, the maker and the heat-treater.
On the other hand, finding a "bad" piece of a more recent particle metallurgy steel is extremely rare - in fact I don't even know of any quality complaints in the last ten years or so about "powder" steels coming out of Crucible, B/U, Latrobe etc - and they're cleaner, finer-grained, more homogenous alloys with improved chemistry to begin with. That's the whole point.
Contrary to widespread internet babbling, steel mills don't spend millions on developing this stuff just for fun or to be the "new flavor of the month". There are specific and important reasons behind the improvements in stainless/tool steels in the last couple decades.
Whether or not most people would ever really notice or care about those improvements in a knife blade - especially a mass-produced one - is a whole different question. But my clients do care, and so do I.
I am not pointing to the pioneers of knifemaking as proof of anything, simply pointing out a bit of history germane to the discussion.
As was I.It was not my intent to "call you out" on that; your mention of Mr. Hibben just reminded me of a pattern I see often in discussions like these. As you know, I have a tendency to get a bit wordy... it's only because I'm passionate about the whole topic, not because I'm trying to get in anyone's face.
I know that 1095 is tougher than 440c generally. But tell me one thing. Does 440c hold a better edge than 1095 carbon steel. Initially l didn't think so ; because while l have plenty of 1095 knives ( 8 fixed blades and 5 folders ) the only 440c knife l have is a Jack Crain Predator 440c machete. But today l had a chance to use my 1095 friction folder and my fathers 440c Gil Hibben Alamo Bow ie. 440c holds a better edge. I would like to correct my ranking of steels purely in terms of edge retention as :
1) D2 ( best edge holder IMO)
2) A2
3) ATS34
4) 440c
5) 1095.
As many of you guys say ; 1095 takes a finer edge like what you might expect from a surgical knife or razor. 440c takes a toothy edge but holds it far longer than 1095 's fine edge.
2) A2
3) ATS34
4) 440c
5) 1095.
