Originally posted by not2sharp
Nope, too limited in application. Aside, from Filleting million ton oil tankers, I would be hard pressed to find a use for it.
not2sharp said:No, it was for a wood chopping machete.
I would like to order a special Ang Khola Bowie. This knife would be similar but longer then the standard knife.
1) The blade should be lengthen to 18 inches (45.5 cm)
2) The blade's width remains as per the standard HI AK Bowie
3) The blade's maximum thickness at the spine remains at 1/2 inch (1.2 cm) as per the standard HI AK Bowie
4) The blade should be made without a cho.
5) The blade has two fullers on each side as per the standard HI AK Bowie
6) The handle should be lengthen to allow the use of both hands. A length of 9-10 inches (~24 cm) should be enough
7) The handle width remains as per the standard HI AK Bowie
8) The handle thickness remains as per the standard HI AK Bowie
9) The handle is chiriwa and has a similar shape to the standard HI AK Bowie
10) The handle has a small oval guard (either steel or brass) about 3 inches high by 1.5 inch wide and 3/16 inches thick.
11) The guard is mechanically held in place against the blade by two 1/16 inch liners
12) The liners fit underneath the entire length of the horn handle material and secured by the handle rivets.
13) The sheath and other items are similar to the standard HI AK Bowie
This version of the AK Bowie is intended to work as a heavy machete. It should balance so as to be able to chop wood, and it should have a strong edge. I have attached some pictures showing how the finished knife should look.
n2s
Bill Martino said:Remember we almost got an 800 pound Salyan because a 7/16 of an inch blade thickness somehow had turned to 7 inches by the time the kamis got the info. Thankfully the kamis questioned me before making it and told me the khukuri would be too heavy to use very well and that I should consider a thinner version.
