- Nov 28, 2006
nozh2002 wrote "I am not sure - may be sombody correct me if I am wrong, I do not remember where did I read it, but Sandvic is the name of mountan in Sweden wich has iron ore deposit and this ore by nature has no any S or P in it - usual addition to ore which everybody else try to get rid of in steel production."
I'll be happy to correct you. Sandvik is a Multinational company with about 40 000 employes in over 150 countries. There is no mountain named Sandvik, although the head office is located in Sandviken, Sweden.
But Sandvik does make pure steels, but that is about process control and not the quality of the iron ore.
As for the 13C26 it's a razorblade steel as many here have pointed out. Used by the major brands on the market. Sandvik is one of two major worldwide players in this field.
Just a comment about carbon/chromium content: The combination of these two elements produces hardness in the shape of carbides. If there is excessive amounts of carbon+chromuim it will end up as large primary carbides. These will not dissolve during forging or rolling. These carbides will make the edge micro-serrated for good and bad. Good for cutting maybe cardboard, bad for cutting meat (it will rip the meat instead of cutting it).
The razorblade steel 13C26 is designed to have as much chromium as possible for a carbon content of 0.65%. For a razor primary carbides are unacceptable. To me it is somewhat strange that it is so widely accepted in the knife community.
Hardening facts: By correct "traditional" hardening 13C26 will end up at 59HRC typically, by means of deep frezing to -70 degrees centigrate it will go up to about 61 HRC. Good for edge retention but problems for the guy who uses his knife as a screwdriver. Toughness and hardness are basically opposites.
