Typical as quenched (with cryo) hardness is 63-64, so to get 63 you'd have to have an extremely low temper, probably less than 300F.So for my entertainment and edification I would love to see a Leek with a 13C27 blade at 63 RC, but I will be more than happy to have one at 59 RC. I might even have the blade heat treated again if I want to play with it at 63 RC.
That sounds kind of backwards to me. The Sandvik stainless grades, since they are primarily carbon and chromium, which are quite cheap compared to molybdenum and vanadium, allow them to keep the price low, among other things. There's no reason to raise the price. And, honestly, I don't think they would sell more if they raised the price. At least Sandvik wouldn't.One thing that strikes me in this forum is that Sandvik seems to be selling too cheap. At a higher price tag, would not a lot of your questions go away?
From my perspective, being a Sandvik fan, it performs well against any other steel grade out there. Thats including S30V and 154CM, but they are never talked about as cheaper alternatives, because of their price tag.
Any metallurgic or steel-fanatic out there kows that excessive amounts of Carbon/Molybdenium/Vanadium etc. just ends up as big primary carbides making the blade dull/microserrated. You can get the hardness and the edge retention you are looking for in 13C26, why pay more for 154CM?
I was not aware that the steel itself was any cheaper than 154CM but only that it was easier to work to make the blades which made it cheaper.
STR
For what I use knives for, 13C26 (well, in my case, AEB-L) is my favorite steel. I don't have any experience with AUS-6/8 so I'll exclude it from my comparison, though it may be similar, but however well made the AUS steels are, I know that Sandvik is of the highest quality with very little impurity. I've seen micrographs of a .65% C 13% Cr steel, and it had some larger primary carbides, whereas I know AEB-L does not, so I don't think all steels with that composition are created equal, the way it is made contributes too.To Larrin,
I understand your point, although I'm not sure you understood mine, maybe I was not clear enough in my rambling.
I'm only adressing the performance discussion, not the price/cost of making steel. So I will rephrase my question a little.
Compared to the high-alloyed steels out there, how do you think 13C26 performs?
I've had knives in S30V, 154CM and D2 steel which I payed far more for than my Sandvik 12C27 knife (made from a european brand). Imho I belive that Sandvik stands up good against any of them, my D2 was worst by far. I did however have some personal issues admitting this since my cheapest knife was in fact my favorite. Had it been more expensive I would have expected it to perform better than if it was cheap.
I dont care about moybdenium if all it does is making my knife microserrated and overpriced, do you? I pay for the overall features of the blade, not 2% Mo.
How do you guys rank 13C26 against S30V, 154CM, D2, AUS6-8 etc?
//Jay
I've never seen a recommended temperature from Sandvik, and neither gives a range that I've seen. I've only seen a single temperature recommendation from Uddeholm on AEB-L.i was under the impression all these steels (aeb-l and sandviks) are recommended to be tempered at low (well relatively) temperatures? like 150-250°C or so for best corrosion resistance. btw jay welcome to the forum
It is cheaper.I was not aware that the steel itself was any cheaper than 154CM but only that it was easier to work to make the blades which made it cheaper.
STR
He used both. His results are on this forum, I'm just too lazy to find the link. I think his first post says that AEB-L got 80 cuts but it actually got 90 (or something like that), he corrected himself later but never changed the original post. CPM-154 cut longer than convential 154CM, partly due to being one Rc higher and due to the better microstructure over the conventional 154CM.Did Phil Wilson use 154CM, or CPM 154 in his rope testing?
Molybdenum actually forms very little carbides in 154CM, something like 3.5% is in solution with the lower temper. It contributes to corrosion resistance, hardenability, temper resistance, and to upper tempering, and I've seen conflicting reports that it contributes to toughness. I think they used so much because it was designed as a bearing steel, which may require higher operating temperatures, which requires an upper temper. As an example of why it might be better than a balance of C and Cr, 19C27 offers a very high potention for hardness, with a sacrifice for corrosion resistance. If you add more chromium, you basically end up with 440C. If you add molybdenum, you end up with 154CM, that has a similar potential for hardness, but higher corrosion resistance, plus the other benefits of molybdenum; however, I think 19C27 has a lower carbide volume, which means it likely has higher toughness. I don't know a whole lot about molybdenum, but you can add up to 1% molydenum for some corrosion resistance and temper resistance without throwing your C and Cr balance too far off, though it still lowers the potential C and Cr in solution. The more you add, the more it changes the balance. 154CM's phase diagram looks way different than just a C and Cr diagram. And a .8% Mo, C/Cr phase diagram is a little different than a plain C/Cr diagram as well, you can see the differences in the free online Verhoeven book.Larrin,
Thanks for the elaborate answer, I appreciate it.
It would seem that in the end it's the size of the carbides that do a lot of the difference I think, and it is in line with my own experience.
Small carbides will give the hardness required->edge retention. Also it will allow the blade to be sharpened in a better way than a blade with bigger (primary) carbides.
For rope cutting I guess that a micro-serrated blade would advantageous, so the 154CM would be the best one when you really need the big carbides.
In what situations would Molly help? Is it not just a carbide former like carbon? In theory it would seem that you could achive the same characteristics with balanced C and Cr.
//Jay
Carbide size contributes more to a keen edge than grain size, but it also has a very fine grain size. Obviously, if it's a razor steel, it must have the ability to take and keep a very keen edge. For high end custom knives, especially, where we often have very thin grinds, AEB-L/13C26 is great.the carbides might be small in these steels but i think the biggest advantage is the tiny grain structure (the carbides are situated between these grains), thats why they use it for razors and similar. ive read 13c26/aeb-l is very very fine grained
