and it brings us back again, convex edges are not automatically thicker or thinner than v-ground edges, it is determined by the geometry selected. With a scandi grind, a 12 degree edge is created by a single 12 degree grind, per side. With a flat grind, the height and angle of the grind are independent of that 12 degree edge, and will determine the bevel thickness and width. The same with a saber grind, which is just a flat grind not taken to full height. The slope of the curve can be changed dramatically along its length if the user chooses, and the angles of the grinds, and the number of separate flat grinds, can also change. There is no universal answer for which grind is thinner/thicker, more acute/obtuse.
