- Jul 20, 2021
What if the m4 blade comes with a dark gray coating on it already? (Benchmade)
How long should that coating last?
try this ...........................https://bladeforums.com/threads/phosphoric-acid.1654333/I'll need to do another. I'm not comfortable posting it for general public consumption for a number of reasons. (ETA: It's just plain yellow mustard lightly dabbed onto the blade with the tip of my finger.)
In my experience, CPM M4 doesn't take a forced patina as heavily as some other steels do, but it still protects the steel just fine. Generally, it just shows light rainbow-like coloring similar to @unclekurty's pic above (hard to photograph, have to get the lighting *just* right). Usually only a small amount of gray staining.
CPM-M4:
M4 with a couple others (Maxamet and Rex45):
Close up of the other two:
Another one, 52100. It seems to patina more than most.
K390 as well (it patinas pretty heavily too, but not quite as much as 52100):
I'll believe it when people do reasonable comparison tests.there is a type of WD-40 called “Specialist Corrosion Inhibitor”. It’s supposed to absolutely prevent rust and it’s $10
That’s fair. I haven’t tried it and have only seen anecdotal evidence of it working on YT, which means jack. I would like to try it, and many others, on 1095 and see how well it works in a saltwater solution.I'll believe it when people do reasonable comparison tests.
I've watched a lot of tests and although the results can vary from test to test, a lot of the recommended protectants really don't work all that well. In my own experiment Birchwood Casey Sheath worked the best, Royal Purple Maxfilm was next. These both leave a somewhat greasy film on the surface which may be why the work well. You may not want this on a knife that you use. The stuff sold by AG Russell didn't work very well, neither did Renaissance Wax.
Why would I want to try that? Mustard works quite well for me, and I am very happy with the results. If it ain't broke...try this ...........................https://bladeforums.com/threads/phosphoric-acid.1654333/
I like natural patina formed with time.......
There was a difference in those steels you mention and now.I've carried knives daily for 40 years, and never required "extreme edge retention" and "toughness" in a blade. Hecky, even "the greatest generation" won WWII with cheapy carbon steel traditionals. Are you guys using your EDC blades in lieu of wrenches to rebuild cruise ship engines? I guess I could see an oil platform worker or roofer wanting that kind of blade (though a utility blade is supreme on the roof), but most of us are using them to open Amazon packages. Seriously, unless you are prying up manhole covers, under what circumstances does a blade steel have to be "tough", and why not use a hammer or pry bar instead?
Kids, these days!
In fact I am waiting for my custom CPM Magnacut fixed blade.
