DaveH said:Since this thread is rapidly degenrating into what makes a sebenza worth the money, I'll just help it along.
Any knife that doesn't have a pivot bushing (like a sebenza does) will sooner or later develop blade play and action problems which will require either user or factory servicing. Further. sometimes servicing even by the factory may not fix the problem. IMO that design element alone is quite significant.
It isn't that it makes a poor working knife, it has many of the attributes of a solid user knife, however the same attributes and more even are found in other more inexpensive knives.Fisher of Men said:To me it seems as if the Sebenza is simply a collectors item
DaveH said:Unfortunately if you just type sebenza into the search, it won't work. You have to add some other term.
Fisher of Men said:And what happens when the pivot bushing wears out? It needs replaced too. All bushings eventually wear out.
WadeF said:As far as saying Benchmade knives are an 80% knife, what the heck is that supposed to mean?
Yes, and often times you will see them with the blades subjected to such heavy wear that for example the serrations are wore off, the same would be done with a Sebenza unless you got the blade replaced and it would be cheaper on many Spyderco models to actually buy a new knife. It isn't as if Reeve would replace the knife for free.tortoise said:...sometimes Spyderco, for instance, will tell an ELU to retire a knife.
