- Apr 11, 2016
And yet, like a troll, you keep coming back.Typical from what I've seen on this garbage forum though.
Garbage in, garbage out.
Good suggestion. If he has one of the knives from that company, then he can stick his Dick in it as well.I'll say that, if money really is no object, then get an F. Dick pull-through sharpener. They are used in commercial settings and they run about $1,000. Or go for their water cooled machine that runs about $2,300.
Yeah, he could sure use one of those.F. Dick pull-through
So buy a knife, use it and throw it in the garbage. Time's too short to sharpen knives when you're rich.Not helpful at all, but a valid point and opinion regardless. Unfortunately you don't realize how large of a disposable income I have. So just assume money is of literally zero concern. I just want something very easy, always. My free time is what's limited, not my budget. I prefer to keep what I have and like, but can easily replace if need be.
Some are better/worse than others:So essentially I'm right to stick with generic pull through sharpeners. Thanks for confirming that.![]()
My mother had an electric can opener that also sharpened kitchen knives. She loved it and used it for decades.Never heard of a motorized drag through. Interesting idea. Oh well. I'll keep looking into more options and hope there's a suggestion that suits me.
Those are steels, which are meant for use on food service and meat cutter's knives. They will likely not work well for the context being described here.Huh, turns out that F. Dick makes a line of manual pull-throughs, that look as though they will adjust to the angle of the bevel.
Rapid Steel: DICK
www.dick.de
A hundred bucks, but that should be no problem for our billionaire friend here.
I thought that at first, but after reading this in the description of the Rapid Steel version, it seemed as though they were not all just steels.Those are steels, which are meant for use on food service and meat cutter's knives. They will likely not work well for the context being described here.
That's because steels DO sharpen. But they work like files with the teeth running longitudinally. Due to the mechanism by which they sharpen, they are likely not an appropriate choice for this use case.I thought that at first, but after reading this in the description of the Rapid Steel version, it seemed as though they were not all just steels.
"With our Rapid Steel knife sharpener, resharpening is child's play. It saves you time, makes your work easier and the simple handling will impress you. Simply pull the knife through several times and your knife will be resharpened with a precise, optimal cutting edge."
"Our Rapid Steel is available in 4 different versions:
My reading of that is that all but the polish option are actually sharpening.
- Rapid Steel action and Rapid Steel action set: Sharpening rods with a wear-resistant, ultra-hard special coating for high abrasion. The Rapid Steel Action Set already includes the base plate with suction cups.
- Rapid Steel polish: To meet the requirements of boning specialists with polished sharpening rods for straightening and smoothing.
- Rapid Steel HyperDrill: specially designed to meet the requirements of meat cutting with ultra-fine cut rods for honing and smoothing."
Rapid Steel: DICK
www.dick.de
Yes. Those are the two reasons that most knife enthusiasts don’t like them.They get it what I would call "working edge sharp" and I've been fine with that. I have noticed that they remove quite a bit of material. Is this the reason nobody likes them?
