yablanowitz
Platinum Member
- Apr 14, 2006
I suspect backlocks are less popular with "high end manufacturers" because they require more effort to get right than liner locks, frame locks or even the Axis lock. Properly done, they are as strong and reliable as anything out there. In the destructive testing Sal has talked about, the usual failure mode on his backlocks is due to the lock bar pivot pin ripping out of the handle. I rather doubt that can be accomplished without a cheater bar on the handle. It certainly isn't likely in anything approaching normal use, even in what I call normal use.
As far as getting a tip down knife out of your pocket goes, a simple loop of string a little longer than the handle of the knife makes a nice wrist lanyard, and if the end is left protruding from the pocket you can hook it with one finger and pop the knife right out of your pocket no matter how tight your pants are.
