kerry i'm just waiting on a full moon to try that one out
Mace you suck!
no seriously though i always get the bulk of it flat with a 4X36 sander. nice and cool with an 80 grit. then move to 220 nice and easy on a surface plate. and damn are they flat as can be. then i fit em. trim excess from all sides and go from there. so i got that one covered
LRB:
i've had this happen on almost every knife i've worked on. i must have gotten atleast one flat right? man i hope so
i think the tang holes are the next plan. but even as far as not flat enough i've seen handles with mean gaps on em and not flat at all tangs but the epoxy just filled up the gaps and still helt together tight
Fitzo: I've used pops epoxy in the past,and acraglas but 99% of the time its slow cure decon and for the second try on this last knife i used JB weld
I'll have to post picstures if i have some time and also look into that glue wars again and buy some expensive glue and a blast cabinet
new toys!
Chuck: i've tried all the motions and found i kept steadier with the pull in one direction motion. and have gotten the scales very very flat. i've also had this problem a number of times with (whats supposed to be flat) materials like micarta and stuff. again see what i posted to LRB i've seen some ugly fit an finish but the stuff still holds together.
Jim: i feel the pain
JT & Flatgrinder: been there done that with no luck
Caswell: Yeah exactly trouble with even stabilized materials is whats buggin me. I've even had knives i've done with moose and had them shrink a noticeable ammount around the tang without popping off. but this is just killing me i can't see why its not working
Larry: i'll give it a try but i'm just worried about this handle getting some contouring i might blow through to the "epoxy pin"
Bruce: i kind of like that idea, but still a little weary about just the super glue
JDM: yeah he's a jackass huh? all went to his head
ahhh hidden tang isn't my game though. i like the full tang deal. i have thought of the spacer material, but then again i'm having the trouble with the glue not sticking to the tang the handle material always stick nice
Bruce: be careful you've seen those geico insurance commercial with the cavemen right?
Stacy: tried the corby's but still had a little gap after a few days of sitting, i know its not gonna fall off but i sure as hell hat the thought of that look to the knife, and what kind of nasty critters can live in there
Roger: i might have to try that, but have no mill. i'll work something out with a flex shaft though maybe.
Doyle: i'll give it a try. i think ya might have heard it in larry's post a few behind you:foot:
Matt: bite me. yeah i know he's a stinky bastard. when me and larry picked him up last year we pulled in the yard and the local zoo was there hozing and brushing him. they explained it was a community service thing they do
i don't think i have a death grip problem. i've tried spring clamps and tried regulars, but when i pull the handles off i can still see a layer under there. and i barely tighten the clamps. jut enough where they start to catch.
dave: I run the whole blade when polishing it up. i don't hit the ricasso seperately anymore, just for that reason. i figure i might be creating a dip. but like i said earlier havent we all seen knives with terrible fit and finish but they still hold, just a nasty epoxy line there
Leon: its off the tang, i'll have to try some new bonding agents. i'm thinking of the loctite one that was listed in the glue wars
Mickley: i know you know you bonding agents. so i'll go with you ideas. I do use the devcon and i clean everything down with acetone before seembling
Mace: I always buy new stuff, keep the small tubes so its not sitting around. and i keep it away from cold weather
Tool steel: once again i'm waiting to try that on a full moon with the whole kerosene cama cameloeon gig
Matt: you got it there i've had handles stay together and i know a ton of people who use nothing but some type of epoxy and some pins and they have never had this problem.
2Manyknives : yeah i think i'm going to have to look into better bonding agents. because i do the steps above. and yet no luck
Thanks for all the replys guys. I think i need to re-think my epoxy, drill some blind tang holes and double check my pressure on the slabs during gluing, but i don't think the pressure is it.
i also shoe shine sand the handle to polish, using some shop rolls but i've seen that employed in tutorials and shops without problems.
let me try to get some pictures next
