Thanks! I'll have to try the tung oil trick.
As far as the pins, do you think I should have moved the rear pin closer to the spine?
Sorry I should have been clearer. I meant you should try to align the mosaic pattern itself so that both pins are the same. IE if the mosic pattern is oriented somewhat in a cross pattern like yours, try to have that cross oriented the same for each pin so that they match rather than having one rotated at a different angle. Does that make sense?
