- Dec 3, 1999
Here's a couple things that are barely worth my $0.02
First thing I do is drill the holes for the scales. THEN all work is based off those scales fitting up to where they need to be.
You can super-glue the liner to the scale, then drill your epoxy holes through the spacer, and into the scale at the same time.
Part of the problem when you were cutting the scale in that first pic, is you have the area you're trying to cut way up above the vise. That allows it to flex all over the place. Think of the end of your car/truck antenna while you're driving down the freeway. The end of it can flex and dance all around. The base of it is rigid. ALWAYS keep that in mind while mounting something whether it's in a mill vise, drill press, or hand-work in the vise.
Keep up the good work!
:thumbup:
