- Apr 17, 2003
Touch Luck Matt! If nothing else, center punch that bolt end, and drill it out until you just have a thin shell and the threads left. Then, pick out the rest with something long and thin.
-d
Or drill a smaller hole in the bolt end and use an Easy out...easiest way with minimal risk of damaging the ID thread...anything aggressive like that on something as old as that is a HUGE risk and should be last resort. Before using the easy out method spray in the thread for a couple days with WD-40 or CRC that will help lube it and free it up a little.
http://i38.photobucket.com/albums/e121/gegvasco/Easyout.jpg You can get much larger easy outs, judging by that it looks to be a large diameter bolt.
EDIT: Also shock load it a bit, use a punch or something that can get to it and the impact can free it up quite a bit.
