- Jan 2, 2014
The two parts are tightly bound with a cord or leather strap and wedges further increase the pressure. Using a strap rather than clamps provides an even, non-marring pressure even when the block is not yet perfectly square and true.
This small tsuka will have an unusual ki-fuchi, a wooden accent in place of a fuchi. Pacific Yew is a relatively hard and dense wood with a beautiful rich orange colour and natural gloss. In this case, the accent will be attached to the tsuka and have the grain running vertically to add strength and stability, making it functionally more like a true fuchi rather than a floating tsuba.
Core parts ready for assembly, note that the glue layer is very thin.
Tightly bound with an even winding and pressure, then tension is increased with wooden wedges in certain areas.
After drying 24 hours, the front of the block is leveled and trued using a granite slab.
Pacific Yew sawn to size and cleaned up on the granite slab. Double edged saw has both rip (top of photo) and crosscut teeth (bottom of photo).
A kiri is used to open several holes to rough out the nakago-ana. There are several different styles of kiri bit, this one is a three sided type forged from an expired file. Kiri give great control and can be used much more precisely than a standard modern drill bit.
Small coarse files are used to complete the nakago-ana in the ki-fuchi and the piece is cut to size.
The piece is aligned and bound with the tang in place and then once stable, the tang is removed for drying.
Squaring up the block to the ki-fuchi. A saw file removes a lot of material quickly without deep scarring like a rasp.
Yellow Cedar shims to reduce the strain on the harder Pacific Yew and provide some shock resistance. Carved very carefully!
Shims on all four sides, escapement filed to fit the tang.
Drilling the mekugi-ana using a hand powered post drill. The location on the tang is chosen based on an estimate of best placement on the finished handle, and then the actual hole in the handle is placed based on the location of the hole in the tang. The opening in the tang will be enlarged and adjusted using a round file in the final fitting.
next up, shaping the outside of the tsuka...
