- Sep 27, 2007
Sorry for starting another thread with an identical post, but my other thread was winding down and I don't think it will be getting much traffic. The title of the other thread also does not make any mention of my need for help!
Anyway,
I got up the nerve to start the bevel grinding on my mini santoku
I ground at about 45 degrees and brought the edge down pretty close and have done several passes on each side at a slightly smaller angle to walk the grind up a little higher and now I'm nervous. I don't want to mess this one up, so how about a little input? Any last minute pieces of advice before I continue? By the way, most grinding I see is done edge up, spine down. Does anybody grind edge down?
Edit to add: One other question, any opinions on distal taper and when to do it? On my first couple practice blanks I did it by applying more pressure at the tip end of the knife and ease up as I moved toward the tang. Does anybody here grind in a distal taper before even beginning to grind the bevel?
THANKS!
Anyway,
THANKS!
