Awesome! You're learning several of the secrets of sharpening here and this is definitely one of them. It's #7 of my unofficial 7 Secrets Of Sharpening. Spend your time on the coarse belt! By "extra coarse", I'm assuming you mean the P120 belt that came with the WSKO. I was initially very cautious with that belt, but I quickly learned to use it on almost every blade I did. In fact, I think it's not nearly coarse enough for really major jobs. So I'm thrilled that Darex now offers several really good coarse belts that surpass the P120: 60 grit ceramic, 80 grit ceramic, and X200 stiff (200 micron Norax). All three belts are very good, with the 60 being the most abrasive and the X200 being the combination of a fast grinder, but leaving a more refined finish.
I've noticed something using both diamond plates and the WSKO with chips: It seems like the chips seem to hang on for much longer than they should when doing regular sharpening at the intended angle. It's almost like the abrasive digs into the chip and makes it slightly deeper, so that you grind the top of the chip away, but the bottom gets deeper. Eventually it's all gone, but it seems to take far more grinding that I'd expect.
So I've now adopted something Jason B suggested, which is to "cut off the edge" on badly damaged or chipped blades. Jason would tell you to hold the blade 90 degrees to the stone (or belt) and grind the edge flat until the chips are gone and the blade has the approximate shape you want. With the WSKO it's sort of hard to do grinding at 90 degrees because there's no tool rest or platen. So I grind at something like 60 to 75 degrees on each side and cut off the edge, removing the chips and reshaping the blade until I think it's ready. Then I go back to the proper sharpening angle and re-establish a new bevel at the intended angle (something like 15 degrees per side on many blades).
Doing this with the 60 grit ceramic is surprisingly fast, even at speed 7 or so. You have to be careful because the scratch pattern is so coarse and messy, plus that belt is so abrasive that it can throw sparks, which to me means I'm grinding too fast. I haven't had any issues with it yet other than some scratches on the sides of blades here and there.
I'm glad you're making good progress. You're on your way.
Brian.
