Ok my friend, take a deep breath.
Based on what you've read, I'm guessing you work in a professional kitchen. I'm also guessing you are trying to sharpen some blades that are VERY dull. In my experience with the WSKO, a very dull blade can take quite a bit of work with the P120 belt. I've spent as long as 25 to 30 minutes, from start to finish, on a single blade that was very dull. That includes progressing from P120, to X65, to x22, to X4 with 80% or more of that time spent on the P120.
You ask how can you be removing the sharpie, grinding the bevels, and NOT getting sharp? Easy: The cutting edge of the blade can be so dull as to be FLAT. It will look like this in cross section:
\_/
How can you check to see if I'm right? Stand under a bright light. Hold your blade with edge facing the ceiling so that if you brought it right up to your face the edge would cut your nose, chin, forehead. Now look down at the edge of the blade and slowly move the tip of the blade down towards the floor, and then up towards the ceiling. If your edge is flat, you will see a shiny reflective line on the edge. Sharp blades won't reflect light on their cutting edge. Dull ones will reflect light. The stronger and more obvious the reflection, the duller the blade.
With a blade in that condition you'll grind the sides (edge bevels) and remove ALL of the marker and you won't actually get a sharp edge until you bring the bevels in and slowly remove that flat edge. That just takes continued grinding at the same angle, until you remove enough metal to re-establish a sharp edge.
There's another way: Increase your edge angle and you'll form a sharp edge faster. It will be more obtuse, but it will form an edge.
I say stick with it on the coarse belt, check for reflection on the edge periodically, and keep grinding until it's gone. Once you can't see it any more, you're *right* there and about to form a burr.
The blades you are describing are quality and *will* make sharp edges. They are probably just more dull than you thought.
Good luck and post your results!
Brian.
\_/
Brian.
