I'm going to take one more stab at this, as I really want to help the two main posters in this thread.
After the 30 passes on one side and then switch to the other side and make 30 passes, is that considered deburring? Guess I'm a bit confused still with the burr and how to deburr correctly and about the apex.
Let's start with some terms so we're all on the same page:
Burr: A curl of metal that forms by pushing over the edge of the blade. When grinding on one side, the burr pushes up over that side and forms on the opposite side. The burr is very thin and weak, but can feel very sharp.
Apex: This is the cutting edge of a blade. The apex is where two flat planes (the edge bevels of a blade) come together and form a line. That line is the cutting edge. When we say "apexed", we are trying to describe an edge that has both bevels ground *fully* so that the entire blade is sharp. Sometimes someone will sharpen only part of the blade and we don't consider this "fully apexed". It's a fancy word that has a precise meaning in the context of sharpening.
Deburring: The act of removing any remaining burrs from either side of the blade. This is usually done with light force and a small number of strokes or passes. It's common when trying to remove the burr from one side, to have the burr form again on the *opposite* side. We call this "Chasing the Burr" because you are chasing it from side to side trying to get it to go away! Deburring is a more subtle part of sharpening and can be challenging. At least it is for me.
To your questions:
This is IMPORTANT: You Do NOT need to do equal passes on both sides. In fact, once you form a burr on one side, on the full length of the edge, you can form a burr on the other side with just a few passes. So in your example of needing 30 passes on the first side, you'd probably only need 3 or 4 on the other side to form a burr. *Unless* you were switching sides every few passes. The key is when the burr forms. After it forms on one side, it takes very little effort to form a burr on the other side.
I can say that after making 60 passes the blade is choppy as it will catch when passing it over a towel. So I'm not sure if that's the way the blade is supposed to be or not. I did run the blade through a cork, it felt smooth but I could see the blade had remnants of the cork due to the choppiness of the blade.
I'm pretty sure you have a GIANT burr on one side of the blade. If you do, you should be able to catch your fingernail on the burr. Try sliding your fingernail down the side of the blade, and OFF of the edge. Go slowly and if you have a burr there, it will stop your fingernail right at the edge. If so, you need to remove the burr. Try using the next finer belt to remove the burr. Use the slowest speed of the WSKO. Check for the burr after every pass. See if it switches sides. When it's very small or gone, run the blade through cork, and then test for burr again. Light passes on one side and then the other, are a very good way to minimize the burr, or eliminate it completely.
You may have to use VERY light strokes on the belt to remove the burr, but it can be done, at least enough to slice printer paper. You'll get there.
Good luck to you and anyone else trying to get great results from the WSKO. You can do it.
Brian.
