Aluminum oxides
Aluminum oxide consists of blunt shaped grains and is very tough in its lowest refined form. During the melting stage in the production of aluminum oxide, the crystalline structure and its chemistry can be controlled, allowing the manufacturer to produce a family of products that perform differently. Aluminum oxide is produced in a variety of types, and its versatility makes it the most commonly used abrasive.
White fused aluminum oxide is softer, or more friable, than other abrasives. It has high chemical purity (more than 99 percent Al2O3) that gives it an aggressive, cool, fast-cutting action. White-fused aluminum oxide holds its form well. It is used to grind heat-sensitive alloys. These applications make use of its friability and the fact that it cuts without generating high heat. This grain is also used to gring heat treated tool steels, high speed steels, and for internal grinding wheels.
Aluminum oxide fused with chrome oxide is a pink abrasive that is used in grinding applications that require slightly more toughness than white fused aluminum oxide. The chrome oxide component of the abrasive enhances its grinding capacity. Although friable and cool cutting, aluminum oxide fused with chrome oxide exhibits strong form-holding characteristics. It is used for precision, broad surface and toolroom grinding on hard alloy steels.
Brown fused aluminum oxide includes 2 to 4 percent titanium oxide (TiO2) to enhance toughness. (Titanium oxide is also known as titania.) This is the most widely used abrasive, and is used to grind high-tensile-strength materials, and for rough grinding, deburring and snagging, as well as to cut low-alloy, ferrous materials.
Low titania brown fused aluminum oxide has 1 to 2 percent TiO2 content, and is used in bonded or coated applications that require an abrasive that is slightly tougher than white aluminum oxide. Reducing the titania content reduces the abrasive's toughness, but increases its friability.
