- Apr 12, 2009
I wrap my sandpaper around a deep bucket paint stirrer, folds nice and creased to make it fit pretty tightly. The paint stirrer is a hard enough enough wood (I think pine) so there shouldn't be anything that would happen with a soft backing like leather or a mouse pad. I'm pretty sure that what I am getting happening is unusually deep scratches from my diamond stone that aren't being taken out by my sandpaper. I visually inspect the edges after every grit, and off the XC my edges are clean looking, with no apparent deep scratches. It could also be that the burr is being ripped off by the coarse sandpaper, because I don't work it down on the low grits (sub 800), I just work a burr on both sides and then move up.
There's a big change in aggressiveness of the sandpaper, just in sticking it firmly to the backing to keep it from moving at all. When I first started experimenting with sandpaper sharpening, I started with the paper just wrapped around my strop block. Eventually noticed the issues I mentioned earlier, and that's when I started progressing towards a firmer setup, doing like you've done, with paper wrapped (but not stuck) around hardwood, then eventually using some temporary adhesive to stick the paper down. Things noticeably changed for the better when I did that, and the progress continued as I started doing the same with progressively harder backing (glass, and I sometimes have used a granite reference plate similarly). When the abrasive can no longer move at all, either down into the substrate (too soft) or laterally under the blade (slipping or lifting from the hard backing), that's when it starts really digging aggressively and efficiently. Edges produced by doing so will be a lot crisper and cleaner, at least with steels that aren't high in VC content. For those, I'll go to the diamond.
I've avoided using extremely coarse diamond hones the vast majority of the time, simply because the scratches they produce are so very tiresome to remove. Looks like you're noticing this too. Unless I were sharpening a very large and/or very thick blade, and needed to remove a ton of metal, I'm content to use nothing more than a Coarse diamond for re-bevelling and similar heavy grinding tasks, even if it takes a bit longer to get it done.
David
