Naturally, easy. It's not going your way, so it's trolling. Don't you feel like you're engaging in projection/accusatory inversion, Boss1911?
Knives with huge flat portion and thin stock are inherently more flexible, it has nothing to do with the property of the steel.When I see how Tramontina or Cold Steel machetes withstand shocks and bending compared to Busse, it drives me crazy.
If you can’t tell apart the design factor(shape of the knife), from the material property factor, there is no way to evaluate the quality of steel.Along those lines, Mike Turber recently snapped 1" off a Busse Basic by flexing it past 50 degrees. Out of curiosity I took a 12" Ontario machete and jammed the tip in a stump about 1" and flexed it to determine the fracture point. I bend it so the handle was past 90 degrees to the tip (which was distorting the wood so the actual bend angle is a little lower). Does this indicate the 1995 machete is "tougher" than the Basic? No, it can handle a much larger flex because it it thinner and a little longer. However what is important is that I bent the machete with one hand with little/no effort. It took Mike all he had to bend the Basic. The strengths are very different.
This is a typical old fashioned myth, softer steels are never guaranteed to be tough.Thus, the best choice depends on specific needs and the context of use. However, in reality, my reaction and choice based on my personal experience lead me to prefer a soft steel knife that I need to sharpen often, which bends but does not break, and that I can straighten to continue using, rather than a hard steel knife that keeps its edge well but risks breaking into one or more pieces, rendering the tool mostly unusable. Therefore, Busse knives, especially the choppers, which fall into the latter category, are not among my preferred choices.
I can feel your internal torment through these posts.Naturally, easy. It's not going your way, so it's trolling. Don't you feel like you're engaging in projection/accusatory inversion, Boss1911?
From what I’m getting at. Your preference might not include knives at all, but machetes. I see where you’re coming from, machetes are near unbreakable by nature because of the way it flexes. It would be pretty ill fitted in prying anything though, or stabbing through anything in an extreme survival situation due to the flexibility.Your points of view are entirely understandable. However, my preference is for a knife that can bend and be straightened, as opposed to a knife that might break. This is a matter of personal choice depending on the intended use and the situations in which the knife will be used.
Busse knives are often praised for their extreme performance, offering an impressive combination of hardness, wear resistance, and edge retention. However, even high-performance steels can break under certain conditions. A knife that breaks becomes useless in a critical situation.
Knives made from softer steel or treated to be more resilient are generally more flexible and less likely to break. They can be straightened if bent and are often easier to sharpen. Weakness: they do not offer the same edge retention or wear resistance as harder, high-performance steels.
If you use a knife for extremely tough or abusive tasks, a softer and more flexible steel might be more reliable. It can survive shocks and forces that would break a harder knife. For uses where efficient cutting and edge retention are paramount, a higher-performing steel might be preferred, even with the increased risk of breakage.
My preference for a more durable and flexible knife, capable of bending and continuing to function, reflects a pragmatic and functional approach to knife use. Extreme performance and hardness of some steels can be impressive in certain contexts, but for use in extreme situations, I am convinced that reliability, durability, and the knife's ability to stay in one piece take precedence.
I understand that, ultimately, the choice of the ideal knife depends on personal priorities and the situations in which the tool is intended to be used. My preference clearly goes for a knife that can bend and be straightened rather than a knife that might break, due to the reliability and durability in critical situations. These are the points that make what I consider to be "extreme performance knives", certainly not a knife that breaks like in JoeX's video.
It depends. I had a Martindale 15 Inch bolo machete with a 4.14 mm blade thickness (shortened and modded like an Hudson Bay camp knife).machetes are near unbreakable by nature because of the way it flexes. It would be pretty ill fitted in prying anything though, or stabbing through anything in an extreme survival situation due to the flexibility.
Obviously, you won't feel any more charitable.Sometimes I feel dumber reading these thread posts. Needs the brain cells back for the tequila use.![]()
? ?? What do you know about me and my Charitable Contributions?Obviously, you won't feel any more charitable.
I feel like this needs to be posted with all this how tuff is it really um use it an abuse it! Iv never felt more confident in any knife then the busse an its kin I have now even if I break a blade “i don’t think I could”ops now you have two sharp blades win win in the woods am I right now you have a spear point and something to cut with I’ve been looking for a good replacement for my Esee Izula2, it’s hard to beat it and harder to find a Busse model available that’s similar to it in size. Been eyeing the bear cub for a while now.View attachment 2630186shit hears mine in action cutting wires, I carry mine an use it everyday. Hell I used it to knock out the the metal knock outs in electrical box at work didn’t even faze it.
