- Dec 9, 2005
The D8XX devours steel, but I still wish I had a belt sander for changing the primary grinds on flat ground blades. The D8XX pounds through hollow grinds to give you a flat to the stone edge real fast, but changing a flat saber grind to a zero grind takes some time, as I found out with my Endura Wave. If you use heavy pressure and no water it can speed things up. I rinse mine off every so often to get rid of the crud that starts accumulating.
Let us know how the D8EE works. I know a lot of guys used to the better 8000 grit waterstones really complain about the finish the D8EE leaves, but I have never used it. I remember a thread where Thom Brogan bought one, and after flattening several stones and sharpening several knives he had to resort to lapping it with the D8EF to get it to polish better. Being a diamond stone I would imagine it does cut faster than most waterstones, and if you are used to a 1200 grit diamond finish it should be quite a leap past that in terms of polish.
Mike
Mike
