Why would you want the linerlock to be titanium? It's so small I doubt the weight difference can be that big.
In production meaning, this is now in stores or still being distributed? I don't see anyone of these 0770CF in stock.The 0770CF is regular production.
Doesn't look like a machined pocketclip. Looks more like a standard metall clip. And I haven't seen a backspacer on the 0770cf, either.
On the home page of ZT it says:
" Titanium insert liner lock secures the blade without unnecessary weight"
In the tech specs and information it says:
"The sweeping lines of the original 0777 are preserved in the lightweight carbon-fiber handle that fits securely in the hand. An inset liner lock in titanium secures the blade without adding unnecessary weight. Pocketclip and backspacer are machined titanium for lightweight strength. For a final touch of class, ZT adds a handsome oversized pivot."
I have no reason not to beleve it!
I personally think it will come with titanium pocket clip, backspacer and liner lock.
On the website where I pre-ordered the knife the same was mentioned.
Thanks for the info! I don't care if it is a steel liner. Still think it's a hell of knife!![]()
A lot of people are under the pretense that Ti is inherently stronger than steel, so they think that steel is somehow a downgrade.
Ti can be stronger than steel, given a set weight. Weight is the key here, not mass. If you were to take two lock bars of the same MASS (NOT weight), the steel lock bar would be stronger all day every day. If you took two lock bars of the same weight (the Ti lock bar could be made more robust than the steel per the same weight) then the Ti bar could have more strength.
This confusion (in my opinion) has led to the rabid idea that it's Ti, or it's crap - which is ridiculous.
Correct, but I think you mean volume vs weight. Two items that have the same mass will have the same weight under the same pull of gravity.
Titanium is about as strong as steel, but has a lower density than steel, so you can use more of it (i.e. thicker liners) and still have the same weight. But since they're thicker, the end result is a stronger lockbar.
Yes, but who wants to fly around to different planets and moons with a triple-beam balance and argue about this there?
Wait...that actually sounds awesome... *grabs a balance and runs off* Peace out!![]()
