- Jan 13, 2007
Pics or didn't happen.![]()
Sorry. Got dizzy, fell on the camera, and broke it.
Can't please everyone, you can at least pick the one (if any exist) that meets the bulk of your criteria. I guess the ultimate goal is to build the item that pleases as many people as possible and for a reasonable price. Doing the best one can is the only thing a person can do, there will always be detractors and praise on the way shortly.
How much does the pivot actually stick out? Or is it an optical illusion?
My guess would be somewhere not enough to be an actual issue and just enough to rack the nerves of the OCD.
Check with Dave (Kershawguy.com). He may have some left.
Mine came in today, and it is a beauty!
Some initial impressions (having only had the knife in my possession for about an hour so far)... The CF scales feel great in hand. They're smooth, but still pretty grippy (more so than the aluminum scales). ZT added a little jimping to the flipper, so it is easier to catch with your finger and deploy. The jimping along the liner lock was removed, which doesn't appear to affect grip (when open) or when disengaging the lock. True to ZT's pedigree, the knife has a very solid feel to it. The CF scales themselves look fantastic, and it's semi-polished on the inside of the scales as well (probably not really polished, but smoothed out to where you can see the definition of the carbon fiber). The barrel spacers were swapped out with a solid backspacer, which looks more like the 0777. The oversized pivot also looks great, again, more resembling the 0777. Final thought... YOU NEED THIS KNIFE!
And now some pics (click for higher res):
As you get yours in, Post More Pics!
If it's 1/32 of an inch, you should be able to insert a piece of paper between the pivot screw and the scale. I can't do that with mine. Can you do it with yours? If you can, your knife is defective. Return it to your dealer for an exchange or send it in to ZT for repair or replacement.The pivot screw is not flush with the handle scales. It maybe sticks out 1/32nd of an inch. You can notice it if your rub your fingers across the length of the scales, but that's about it. It is unnoticeable in hand when cutting, as well as in pocket. The pocket clip screws actually stick out further than the pivot screw.
The ZT site says "in stock" as I write this.
Does anyone know who the designer is?
