Have we discussed forge heat treating?Neither does the guy at AKS!!!
Chuck
My pottery kiln does a pretty good job. You can often find the round ones that are around 14-15" ID. It's top door, with the heating elements in the top lid, but goes to 1715 with a PID controller. You lose heat opening and closing, but it's back up to temp pretty quickly. Mine takes about 90 min to get to 1500, but its a 110V model and has a lot of extra space to warm up. I will probably make my own HT oven down the road, longer/narrower cavity, front door, etc.
What your email address?I sent you an email or someone at AKS about not needing to normalize O1 and 26c3 and that I thought they were easier to do in the open atmosphere than 1084, which a lot of woodworkers will try and fail with.
I'll send it to you PM.What your email address?
Chuck
We have been trying to get .090"-.110” O1 for more than a year, but the supply is been getting more and more limited. I will buy it if I see it.
I suggest you read the O1 datasheet heat treat information. When austenitizing O1, it is important to equalize the temperature and hold for 15 to 30 minutes. This is almost impossible to do in a propane forge. This is the primary reason I only recommend O1 to knifemakers who have a heat treat oven. Alloys like 1075, 1084, 80CrV2 and 8670 are much easier to properly and consistently heat treat in a propane forge.
I recommend using a pyrometer in your forge to know the temperature. Here is a link on Amazon:https://www.amazon.com/Digital-Temperature-Controller-Probe-Alarms/dp/B01I7MIM16
I’ve personally witnessed forge temperatures varying by more than 100°F and the color of the steel did not change. The only way we knew the temperature changed was watching readout. We have pyrometers on all our forges.
Well alpha knife supply puts the exact elemental make up of the batches of steel they sell. So that's the place I would buy w1 or 2 if you are concerned about that.those are also options. At some point, I was warned by an old timer that the W1 and W2 steel quality is a lot more variable than the domestic O-1 offerings from known mills.
Now that I'm further along than I was then, I'm sure I could find a supplier who will actually state the carbon content rather than saying "0.6-1.5%" or some generic spec.
Honestly you can heat treat anything with either setup, if you're willing to put in enough effort, and sacrifice some performance.Looking for what else may have led me to believe you didn't approve of forge heat treatment, from the O1 page on your site:
"Many people think the alloy can be properly heat treated in a coal and/or propane forge. This information is incorrect."
All of the samples above were done in a propane forge. You can see from my order history that I don't drop down into too many steels below the eutectoid limit - they're just not good for woodworking. I tend to get better results with steels that are assumed less suitable for quick no-soak heat treatment, but I've done a fair bit of this and made incremental improvements - mostly in getting higher hardness out of the quench and understanding what not to do if straightness is important (and it always is).
I wasn't being sarcastic or facetious btw. I really meant it. You can heat treat anything If you're willing to put in enough effort. Theres a video on youtube of a guy doing aebl in a forge with a 15 or 20 minute soak at 1950, and hes doing it in a muffle pipe with a thermocouple, and at least the thermocouple is saying he kept it withing 10 degrees difference the whole time. It definitely took a lot more effort though.I guess my point is that for the two steels I'm showing, you can compare the results to Larrin's write ups. I'm not sacrificing anything with those two.
Without working up a routine and snapping samples with other steels, I don't know if I could match the book on anything else. I think I could, but sending samples to larrin let me know that my routine isn't a cure-all for everything with below O1 and 26c3 on the charts.
I also don't have machine tools, so creating endless samples that would fit in a standard machine requires me to hand dimension the samples, which is a pain.
I wasn't setting out to prove that you could match results in a forge, though, but rather to put together a routine for a bunch of people who claim they want to make their own tools including the metal parts and heat treatment. As in, they're doing something as a hobby and $200 of equipment is doable for a side item, but $2500 isn't. I use about $200 of equipment, maybe $300 - my HT forge is small with very focused heat, and a two burner larger stainless forge that I have is sitting idle in the shop. It makes a lot of heat, but it lacks the control that I really want, too.
Larrin is my oldest son, I am involved in most of the testing that he does. I did the heat treating of the 52100 samples talked about in his book. I’ve been forging for more than 36 years and making knives for almost 45 years.It's king for knives, but its toughness is a problem for woodworking tools. In the back of my mind is that when I do finally get a furnace, it's one of the steels that I'll be able to nail, though. My go-to on O1 and 26c3 is sub-critical thermal cycling, and I'm sure that doesn't do great things for free chromium. Since I don't re-normalize, I always get a very very tough steel that I still think something is coming up short in it. I can get it sharpening stone challenging hard out of the quench and temper it back a little and it makes an initially nice woodworking tool, but the edge actually wears in a slightly different shape - a little more rounded.
And then it spanks you in chiseling or planing by holding on to little defects if they occur - it's so tough. 3V does the same thing.
That may not sound believable from a knife man's perspective, but I may be the only person in the world who is experimenting with this stuff - finding out why some things aren't used in tools. For example, O1 is used fairly often. 52100 has about the same edge life through wood if you bear down on a plane, but it's more physical work to keep it in the cut.
here's a picture of the worn edge on a woodworking plane iron, 52100:
52100 carbides
26c3 carbides
O1 carbides - or seemingly visual lack thereof
26c3 has a fairly short wear life - less for me in wood than even 1095, and noticeably less than O1. 52100 is about an even match for me for O1, but the crispness into the cut isn't quite as good as it wears - it's gone in half the time.
This is esoteric for knife folks - what I like is the dry crispness of 1095, but 1095 is just not quite tough enough at high hardness. So, I'm wading into this area of 1% steels that'll temper to about 62 and be a step below 26c3.
I guess 26c3 doesn't have a reputation for great toughness, but larrin tested samples for me and 26c3 averaged about double as tough as O1 and two points harder - I'm chasing that same thing in a steel that will be fine and much like vintage cast steel (the very old stuff) which is likely some kind of ideal ore with a very small amount of helpful alloying. It also shows little to nothing for carbides.
I'm floating around the knife forums because I do make the occasional knife for someone who wants a knife that won't be sold publicly (thin profile slicer for people who don't pry open locked barn doors), but more because there is just about zero depth re:metallurgy and nobody who likes to spend about 10-20% of their time experimenting among the making.
Your suggestion is a good one, though if you're not doing a lot of woodworking - I just assumed that when I started making chisels, they would end up being 52100 to get the same hardness as commercial chisels with much more toughness. I've also learned that Larrin doesn't like forge heat treating that much - at least from a matter of practicality. Neither does the guy at AKS!!!
If that is the case. Can I bring up, that you mentioned you keep your steels below critical for anything you do prior to austenizing in a different thread D D-weaver ? If you are forging your steels, or getting them from different suppliers you really aren't going to be able to get a proper normalization, or any kind of thermal cycling in a forge. by keeping them below critical, and that could compound any other problems that are already happening during your ht.Larrin told me about the testing he did for you and how poorly it performed.
I’m not trying to insult you but you seem to be looking for validation more than answers
52100 tested higher in toughness and edge holding over O1 and 26c3, and many other steels.
I’m not trying to insult you but you seem to be looking for validation more than answers.
52100 has the finest carbides and the smallest grain size of any steel that I know of. It is also cleaner than most steels because it usually ends up as a bearing.
I have used a lot of 50100, 1095cv, and 19c5va. It’s a good steel but it’s not as good as 52100.
52100 requires precise heat treatment.
Hoss
Good luckDevin - the second set went poorly. The first set, the results are shown. If they are poor, I wouldn't know why - the O1 samples match Larrin's tables. The 26c3 samples match larrin's hardness but the toughness is higher than larrins.
I sent the second set, and communicated to larrin that they were done with the same method as the first, and probably incorrectly assumed the second set would do as well as the first.
I could repeat the results in the first set (O1 and 26c3) 100 times and the results would be about the same. I couldn't make any realistic comment about 1084 and 1095 because I've made 3 items out of 1084 (tested one as a plane iron, but it was a few years ago) and the 1095. I made one chisel out of (poor results - before parks 50) then after getting parks 50, three plane irons. I never followed up further on those two because I don't use them.
Put differently, I paid my dues on working up 26c3 and O1. I guess with the others, I was hoping I could use that for a free lunch. The results from larrin on those were a good thing to learn - I can't think of anything that provides a better lesson than poor results.
But I can't emphasize how disappointing it is to hear that the conclusion after the first set, as shown, that I only had very poor results.
I could do one of those per day on different days 10 days in a row and send them to larrin and they'd be the same - but for what conclusion - well the results are crap because they were for others? I don't have a great deal of incentive to come up with something for 1084 or 1095 and while I'd say I could do any number of samples of O1 and 26c3 and the result just make more dots on those charts, I wouldn't even go so far as to say "I know I could come up with good results" on the other two, I haven't done it. who knows.
What was I really looking for here? I was hoping someone would perhaps be able to point me to a retailer who had 50-100B or 50-110B and just didn't have it listed. Or anything somewhere close to that.
The problem with 52100 having too much toughness for woodworking tools is a legitimate problem. It caused problem in chisel tests for me - 26c3 next to 52100 and the fact that the edge will hold deformation instead of letting it go leads to significantly more effort being spent with a chisel to do something like cut half blind dovetails in furniture. Before that, I questioned why stanley and others didn't use it early in the 1900s - they used water hardening steel, oil hardening steel and what seems like something with a little bit of tungsten in it. I think I know why now.
Not sure what triggered the discussion of the second set being poor in the first place - was it being surprised by the good results on the first one? I don't know.
This whole lump it all together and the results were bad is annoying, though, but it doesn't change outcomes - I still have only two steels that I use and I'm looking for a third. The fact that nothing else shakes out other than maybe W2 is more disappointing. If you had a pile of 50-110B and you wanted to tell me that my shoes were dirty but you'd sell it to me - I'd be perfectly happy with that.
Lastly, the fact that I can nail the two steels that I generally work with has some to do with things i learned from larrin's site (how much time do I have, to chase hardness at the tail end by getting the steel as cold as possible as fast as possible) - I guess it is what it is. I'm more pleased to learn it and less concerned that larrin's more interested in the bad results than the good ones - I'm not a sentimental guy.
