- Mar 1, 2008
I found it a couple bucks cheaper at another one so I went ahead and got a backup. I'll probably have to get the bone now so I can save a matching set and start thinking like a hoard...er uhh hmmm I mean collector
Mike's rating of the action as a "2 out of 5" has me quite apprehensive about my possum skinner now. Especially since the stockman was a 3 out of 5.
I found it a couple bucks cheaper at another one so I went ahead and got a backup. I'll probably have to get the bone now so I can save a matching set and start thinking like a hoard...er uhh hmmm I mean collector![]()
rating a knife’s ‘action’ and ‘pull weight’ is not a black art. It is simple physics - and a lot simpler and more scientific than some folks make it out to be. The principles are set out here http://www.npl.co.uk/upload/pdf/forceguide.pdf and apply equally to any task which involves measuring the force needed to move an object.
If a knife is rated a 4/10 as a pull weight and a 2/5 on a walk, I think this is simply saying the pull force and the closing force are the same - which they should be - and the blade is opening and closing cleanly against the force of the spring without interruption. By that reasoning, the walk rating should only rate ‘less’ than the given pull rating if the walk is affected by excess friction in the joint - such as when the bolsters are over tightened or there is material clogging the joint.
From what people are saying, I expect this knife has roughly the samue pull weight as most large stockmans have.
So we should be good!
Action is the perceived “walk” of the knife, the flow and spring force throughout the full motion of opening / closing; from 1 (the blade has to be pushed open/closed) to 5 (keep your fingers out of the way).
I think the last explanation ‘5 (keep your fingers out of the way)’ is mixing up the pull strength with the smoothness. A knife can have low pull strength and yet still have good walk, and vice versa.
Also, I would remove the ‘perceived’ aspect of these ratings. They are all measurable qualities - as your force meter has demonstrated.
I have experienced plenty of knives that had a pull on the lower end of my scale; but popped from full open to half stop with much more authority than anticipated. I don't have a rating for "smoothness"; only a flow created by spring force end to end. So, if the spring force transitions the blade outside what one would anticipate - keep your fingers out of the way.
Also, the "perceived" aspect is key because nobody has ever come up with a true agreed measurement - specifically where to measure / how to measure. I see people all the time rating a knife and 8 that I have rated a 6 - it is not universally measurable.
This is the one area that Case knives have an advantage over GECs, they have lighter pulls, smoother half stops, and great snap open and closed.
One rating I'd like to see is the effort it takes to overcome the half stop. GECs are easy enough to get to half stop with the nail mark, but opening it the rest of the way can be a bear on some of them. Especially if your fingers are slippery or wracked with arthritis pain that day. Riding the nail mark all the way open is an option, but sometimes with a wicked snap it will tear apart the finger nail. This is the one area that Case knives have an advantage over GECs, they have lighter pulls, smoother half stops, and great snap open and closed. Either that or we push on the blade edge with our thumb like Mike, but I ain't doing that. Lol
I asked a dealer to check the action for me and send me one with a stiffer snap if possible.
Here is a snip from the email..... "Just to let you know, I checked all the Skinners I received and in my opinion, all have a pull of 5 or 6 on a scale of 10. The snap to close is good."
Sounds about perfect to me![]()
I have always opened my knives in the same manner as Mike, pushing on the edge. I don't care how sharp they are, it has never been a problem, for me. It seems funny that so many are absolutely freaked out by it!![]()
Well, I'll leave y'all to it.
