2019 GEC 92 Eureka Jack
The size, the shield, the domed pins, the wraparound spring for the coping, pull strength and the nice bone make this one of, if not the best, GEC two-blade jacks. For personal preference I would have a clip or drop point main with a mark side coping in front, but that in no way detracts from the quality of the package. Mine is tip top.
Jeff, good description and I hope mine looks that good, nice color
They are an instant classic indeed!
If I recall correctly Jeff...I believe you were the first to suggest the "Reverse Orleans" shield during the BF knife discussions. I'm glad it came to fruition on this one!
I also have to agree with you with my preference for the coping on the mark side (and also that it's not a huge deal). I prefer how it looks, and I like having both blades available without flipping the knife over.
My speculation as to why they changed this from the 2013 models - is that the coping blades did somewhat obscure the long pull on some of the Northfields. Just my best guess though.
A gem! :thumbsup::cool: Hope mine looks as good...should find out tomorrow.
My 92 Elderberry came in today. I’m really excited to have a Eureka Jack in hand finally as it’s been the pattern I’ve most sought since joining to forum. Mission accomplished. :) I’m really liking it so far and I can’t think of a better blade combination for edc uses. A small, straight coping blade for packages and whatnot, and a longer drop point for food. Perfect.
I do think I would prefer some nice wood covers over the jugged bone though. I’ve always preferred Case’s jigged bone over GEC’s for whatever reason.
Fit and finish is excellent, on par with what we have come to expect from GEC. The pull is pretty light (lightest GEC I own), I’d rate it at a 3.5 or 4.
I’ll get some pics up tonight when I get home or tomorrow before I head out for the weekend. :)
Wow. I'm blown away. My elderberry arrived last night, and I'm floored. It's an absurdly beautiful knife. The red dye job is nice and deep, with no white or bright pink spots. The two-stage jigging is very nice, and works really well with the reverse Orleans shield. The shield choice and orientation are absolute MAGIC on this frame. I didn't actually have any plans for buying the elderberry, but when I first saw pictures of the Orleans, I had to find a way to get one. And that wrap-around spring!!! GEC really pulled out the stops on this run.
The blade choice is pretty interesting. The main blade is quite bulbous. It's obviously a spear, but something about the shape of the tip sort of reminds me of a spey. I'm not a huge fan of speys, but this blade somehow manages to work successfully on the Eureka.
I won't be attempting much fine tip work with the fat spear blade, but that's where the two-blade design comes into play. The coping blade secondary has a sensational tip for detail cuts. The coping has some wicked sharp angles to it, which is just fine by me. It's almost like having an Exacto knife secondary. Overall, the blade shape combination is really, really good. Not at all what I'm used to, but possibly something that causes me to examine my personal biases.
GEC did very well in putting this all together. If I grasp the end of the blade and wiggle, and can detect the tiniest hair of horizontal blade play, which I'm perfectly okay with. I'm of the opinion that GEC has been assembling their knives a hair too tight the last couple years, causing some loss of action when opening and closing. My Eureka opens and closes very smoothly, with a pull of 6 on the main and a 5 on the secondary. Right where I like them to be.
Blades are centered in the wells. Pins are nicely domed. Opening and closing the blades repeatedly has thankfully produced no flat spots on the edges. Transitions from bone to bolster are very good. The jigging actually extends all the way to the bolsters, and patterns the bolsters ever so slightly, which I don't see too often anymore. Some people like that. Some don't. I see it as a sign of quality.
I should also mention that the Eureka is terrific in the hand. It's just crazy comfortable to grip. The frame shape is exquisite. When the main is being used, the dead spot between the main blade's tang and the coping blade leaves a perfect sized resting place for the meat of your index finger. The cant of the main blade is dead on perfect. The angle lets the belly of the blade naturally dig right into what you're cutting. Gripping the coping blade isn't as comfortable. But hey, it's a secondary. You have to make your compromises someplace. And while using the coping may not be exceptionally comfortable, its comfy enough, and far more secure than most coping blades, due to the hook in the tang.
If I had to nitpick....... I guess I've gotten used to Victorinox and Case's ability to sharpen a knife. It's easy for me to fix, but this knife wasn't sharpened well at all. Almost a butter knife, and an uneven grind on the coping blade.
All in all, this is a really great knife. One of GEC's best efforts in quite a while. I've wanted a Eureka for years, and GEC definitely did not disappoint. This a reasonably large traditional knife that somehow manages to be as elegant as it is useful. Hefty enough to feel good in the hand, but without feeling bulky or heavy. Pocketable on its own, but probably better in a slip.
Buzz, excellent description. I was also going to pass on the Elderberry but I finally decided to order one and it should be here today, hope I get a good one like you did.
If I didn't order one I probably would have after reading your write up, I'm sure some dealers are also liking it.
Great write-up and pic, Buzz! :thumbsup: Mine's on the mail truck.
Talked me into it. TKC just dropped another batch so I have an elderberry jigged on the way. Thanks Buzz!
This knife could likely cause me to become one of "those guys"..... you know, the guys that have 4 or 5 of the same model knife, when others cannot even find one of them (you Beer Scout guys know who I'm talking about...:mad:) I like the elderberry, and I like the looks of the calico, and I like the looks of the OD micarta. It's worrying me....:eek:
the 92 has always been knife that eluded me, despite all the recommendations. I am very excited to see them. also its totally fine to have 5 or even 10, maybe 15 of the same model of knife!
I have four or five of several. No guilt no shame.
I snagged a 92 elderberry from a dealer. I consider myself lucky.
I think the 92 camel bone is looking really unique.
Can’t wait to see the jigged calico bone pics!
The GEC posted calico bone pictures are a real disappointment to me . I am so glad I missed that SFO pre-order.
