- Jan 18, 2007
A source from GEC has commented on face book that it is split backed but "not traditional ". So he has us all wondering, and he has not elaborated.Though if it comes with a split back, I might scoop one up out of curiosity.
IIRC that's the set up Case's Seahorse Whittler uses.Perhaps it's two parallel springs with both bearing on the main.
It is split back, just not "traditional".IIRC that's the set up Case's Seahorse Whittler uses.
Fine design, but I wouldn't consider that a split back.
I'm not knowledgeable enough to argue the point, so I concedeIt is split back, just not "traditional".
I don't know enough either just passing along info. We will all know when they are done.I'm not knowledgeable enough to argue the point, so I concede
I always thought:
that a split spring was a single spring split down the middle part way, with two secondaries riding on the split part and one main riding on the unsplit part;
a split back was two springs separated by a wedge with two secondaries riding on the separated part and one main riding on both springs at the unseparated end;
and a knife like the Seahorse was just a two spring knife with three blades, one of which rides on both springs.
As I'm reading the posts above I happen to have this GEC #13 whittler with me...
Eesh, not sure about that. I’ve got one on reserve but I don’t know how I feel about that spring configuration.
I hear ya. GEC's splitback whittler's are solid. I often just stare in amazement how it's put together and everything is perfect. It's one of the best made knives I have. To top it off, the frame is curved.
I believe that is correct.... and unavoidable by design.Is there a gap where the two springs merge? It looks like there is in this picture?
What is the point of a split spring? It seems like on the whole the knife would be a little thinner overall without the split config.
It allows for the secondary blades on one end to ride one spring each separately while the bigger main blade rides on both (the come together on that end and act as one spring basically) and falls in the space between both secondaries when closed. A splitback whittler is considered to be the trickiest pattern in traditional knives, showing the artisanery (is that a word?) and knowledge of the maker. A royal category, if you want.
