Nice one, and great matching sidesi like this stag...
and good stag does not need a shield to be beautiful!
View attachment 1951864View attachment 1951865
A lot of reports of pin cracks.thnx CC, but Huston, we have a problem...
Two #59 ironwood knives both with pin crack...View attachment 1951862View attachment 1951863
Mine had a crack like that on both sides too. I fixed the cracks by very carefully putting super glue in the cracks with a small amount of glue on the end of a needle. Let it soak in, and then lightly sand with 1200 grit. After sanding, buff with a polishing wheel without polishing compound, and it brings back the slightly textured satin finish that accentuates the grain patterns. The fix is invisible. It’s a shame to have to spend this time on a new knife, but I typically do....I also sanded down the “proud spacer” like the 38’s had.thnx CC, but Huston, we have a problem...
Rut Roh. Figures, though, as I just got an order in today for one in DI.A lot of reports of pin cracks.
Ouch!!thnx CC, but Huston, we have a problem...
Wonderful example!!!i like this stag...
That's always a possible issue with some high Janka exotic hardwoods. Driving pins into small scales like these creates stress issues. Usually pin cracks are easy to repair, but sometimes you will get major cracks and separation elsewhere. Snakewood is one of my favorites, but is notorious for cracking down the road. That said if you look at the slabs in the tray on it's sides on the GEC webpage, does it look like some of those scales are already splitting?Mine had a crack like that on both sides too. I fixed the cracks by very carefully putting super glue in the cracks with a small amount of glue on the end of a needle. Let it soak in, and then lightly sand with 1200 grit. After sanding, buff with a polishing wheel without polishing compound, and it brings back the slightly textured satin finish that accentuates the grain patterns. The fix is invisible. It’s a shame to have to spend this time on a new knife, but I typically do....I also sanded down the “proud spacer” like the 38’s had.
I don't see any cracks. I do see predrilled holes. Which picture are you referring to.That's always a possible issue with some high Janka exotic hardwoods. Driving pins into small scales like these creates stress issues. Usually pin cracks are easy to repair, but sometimes you will get major cracks and separation elsewhere. Snakewood is one of my favorites, but is notorious for cracking down the road. That said if you look at the slabs in the tray on it's sides on the GEC webpage, does it look like some of those scales are already splitting?
Sorry, my bad. I meant the snakewood pieces in the 81 pictures being prepared.I don't see any cracks. I do see predrilled holes. Which picture are you referring to.
I don't see cracks. It seems (like I tell my daughters) you're borrowing trouble from something that has yet to happen.Sorry, my bad. I meant the snakewood pieces in the 81 pictures being prepared.
Likin’ that one!My stag came today and I’m happy with the covers. Evenly matched and just gnarly enough. Just a small amount of rub on the pile side main blade. Can’t decide which I like better the HB acrylic or stag.
View attachment 1955528View attachment 1955529
Congrats on the nice set!
