- Jan 18, 2007
So, I regard it as a build fault in assembly (which is easy to fix, but don't overdo it or the spring can become sunk..) . Stockman often have a proud tip but this can't compromise use of the Master blade, can make for a full hand feel though. CASE 18 often have a high rider Sheepfoot and people may lower it to their taste. Not found it very often on other patterns no, all my GEC single spring 2 blade knives are fine- 33, 68, 35, 79, but an early 2011 85 2 blade in Stag has proud secondary- less annoying than on a single-spring knife as the tip is away from you in use.
When the knife is in production/finish it should be checked for flush tips and adjusted accordingly before going out.
Thanks, Will
