I'll keep that in mind, currently trying to work out some burnt looking discoloration in my Sandvik 12C27 helle knife tipThey get a bit rough after Children Of Dune.
That bites man... What do you use for your coarse stone? The guys in MTE will be the first to tell you that's the key.I'll keep that in mind, currently trying to work out some burnt looking discoloration in my Sandvik 12C27 helle knife tip![]()
Dmt but the knife is new, about ready to say (I don't care and use it) how many people nitpick about the stains and discoloration of their potware and flatware? No one reasonableThat bites man... What do you use for your coarse stone? The guys in MTE will be the first to tell you that's the key.
So it's a burnt factory edge?Dmt but the knife is new, about ready to say (I don't care and use it) how many people nitpick about the stains and discoloration of their potware and flatware? No one reasonable
Being years old and still work despite all the surface rust, stains and discoloration and no one bats an eye, should be the same here. Should, lol
Perhaps you dont realize that steel is always a compromise of some type. No steel is perfect and every steel has pluses and negatives. What is your perceived issue with 440c?It's about time we finally can the steel, am I right?
People say it's all in the heat treatment. However
At the additional price point, you are better off buying serviceable 154CM. Thoughts?
Just the tip, worked some of it out, maybe leftover from the heat treatment or the buffering processSo it's a burnt factory edge?
Correct, I'm a professional at dulling 440c at the speed of light and never getting it to cutting shape again.Perhaps you dont realize that steel is always a compromise of some type. No steel is perfect and every steel has pluses and negatives. What is your perceived issue with 440c?
What are you using to sharpen, and whats your methos for doing so? (How do you determine edge angle, grind, etcetc)Correct, I'm a professional at dulling 440c at the speed of light and never getting it to cutting shape again.
Hmm. I will give this a go and try to explain via textWhat are you using to sharpen, and whats your methos for doing so? (How do you determine edge angle, grind, etcetc)
I tend to start from sharpening choil (if there is one) if not, base of the knife
I draw backwards, starting at the top right of the stone, and arriving at the bottom left , with knife tip in contact with stone. When sharpening other side I repeat process in reverse
Sometimes I'll attempt apexing the edge but I only have coarse, medium and fine grit
Can't tell you exactly the grit number, it is a Dmt set of 3 stones in a wooden box, blue, green, red
I was under the impression that drawing a blade backwards while sharpening a knife has a tendency to round the edge, and that to avoid doing that one should sharpen forward as if slicing away the top of the sharpening stone.
I do that because I'm lousy with maintaining an angle going forward, some guy on YT suggested it so I tried it and never really stoppedI was under the impression that drawing a blade backwards while sharpening a knife has a tendency to round the edge, and that to avoid doing that one should sharpen forward as if slicing away the top of the sharpening stone.
Got to that that true 440c. Wont find it inna 10 dollar folderIt's still a solid steel in 2022, IMO. My old Benchmade Grip in 440C is a solid performer. It's easy to sharpen, easy for a user with very limited tools to get a razor edge on, does acceptably well in all the categories, and is tough.
In 2022, it might not be acceptable for an extremely expensive knife considering some of the alternatives, but it's still a very respectable steel in its own right.
In some ways, I think the demise of 440C wasn't even due to the steel itself, but due to a lot of cheap imported knives labeling their blades as being "440C" (even though it wasn't actual 440C), potentially leading many consumers to assume 440C automatically meant poorly-performing steel. (E.g., "why is this $100 Benchmade using 440C?! I bought a 440C folder off of eBay for $10 and it was terrible!")
