It's about time we finally can the steel, am I right?
People say it's all in the heat treatment. However
At the additional price point, you are better off buying serviceable 154CM. Thoughts?
Is 440 useful for forging or is it best used in stock removal?
I apologize if I asked this before... it's late and I'm pretty tired unwinding from a full day...I see people here have great things to observe about 440c, I when only speaking of my own findings is that I dull the steel relatively quickly after few use applications and never can get it back up to a serviceable edge--- I also read its hard-er to sharpen
Sandvik 12C27 and 14C28N I have excellent time with
Yessir, we are lucky to have what we have. I literally just a page or two back relayed a story of my Victorinox edge (considered below 440A) holding up extremely well after hitting stones and pebbles, a real experience I had just done, and the first reply was "That steel is awful and useless! It should never be used in knives etc etc" like... he didn't just read about a success with the steelSteel snobs get so worked up about steels and their composition, when the people who actually use their knives for a living (butchers, fish mongers, etc) have knives that are made from the most basic steels. Have you seen what the fish mongers in India use? A piece of flat bar mild steel, beaten into the shape of a knife in a crude forge and "heat treated" by heating it up in said forge and quenched in water. They don't even bother putting scales on the handles and they are sharpened with a file.
440C is fine
It was a sarcasms... I was even asking on Larrin pinned thread to retest it because I believe that it is better than what his chart shows.Yessir, we are lucky to have what we have. I literally just a page or two back relayed a story of my Victorinox edge (considered below 440A) holding up extremely well after hitting stones and pebbles, a real experience I had just done, and the first reply was "That steel is awful and useless! It should never be used in knives etc etc" like... he didn't just read about a success with the steel![]()
I am sorry, my notifications are screwy and I only just saw your reply to me by scrolling backward in the thread, your point is agreeable, haha, I had just initially misinterpreted you.It was a sarcasms... I was even asking on Larrin pinned thread to retest it because I believe that it is better than what his chart shows.
I would interpret that scale as 4.5(out of 10) being average, maybe slightly subpar in the grand scheme of things and 3.5 being somewhat poor. That's just my interpretation anyway.Sorry to keep beating on this, but I did find a knife nerds source here that also lists 440C and 1095 as having identical toughness. But 440C also has much higher edge retention, plus stainlessness. So again, it’s hard for me to see why I would choose carbon steel between these two. 440C is actually also cheaper, even if it is due to mass production. I understand I’m probably not going to get a handcrafted 440C blade for the same price I can get a handcrafted 1095 blade for, of course.
Knife Steels Rated by a Metallurgist - Toughness, Edge Retention, and Corrosion Resistance - Knife Steel Nerds
Steel Metallurgist Larrin Thomas uses tests of knife steels to rate the steels and explains the factors that control performance.knifesteelnerds.com
Edit: “Cheaper” probably isn’t right. Maybe “equal.”
Edit again: Poor reading skills on my part. 440C = 3.5. 1095 = 4.5. 4.5 is higher than 3.5. But 3.5 still doesn’t seem bad given much higher edge retention and stainlessness. Anyway, not here to beat up on 1095 or claim 440C is the best thing ever, just trying to understand.
How many knives have you used in 440C? It's possible you have a knife that was not heat treated properly, or the factory edge may have been damaged from excessive heat.I see people here have great things to observe about 440c, I when only speaking of my own findings is that I dull the steel relatively quickly after few use applications and never can get it back up to a serviceable edge--- I also read its hard-er to sharpen
I believe that you get it wrong a bit here. Nitrogen does helps in refinement, but Vanex and LC200N has very low amount of carbon, which already help to get finer carbides. The low amount of carbide also reflex on their lower wear resistance on Catra test. MagnaCut "secret ingredient", stated in Larrin's video, is more about Nitrogen than Vanadium.
High Vanadium is not that much different from Chromium when you reach similar carbine carbide volume. The better example would be Crucibles steels with V suffix (S60V, S90V, S30V, S110V, 15V). Not all of them are stainless, they have very high vanadium. For some of them, without the PM tech, they are unachievable because of huge carbide clumps. The "carbon vanadium" only have similar toughness to chromium stainless. As someone mentioned earlier, forging a PM steel will likely cancel out all of the PM benefit.
most stainless knives are from stock removal....
while it's technically possible to hand forge 440c, you need it up over 1900F (to hammer work it and not have it crack on you) - that is like 4-500F higher than carbon steel requires, and it actually makes a serious difference in how much protective gear you need
(also need well ventilated area or fans & outside air due to off-gassing, 'ideally' a ventilation mask setup)
as a result, most places don't hand forge stainless
Death, pierce through me for“I refuse to be caressed by stone.
I now live emotionless and free from your pain.
My heart bleeds the darkest blood.”
Well, it goes without saying that a sandworm tooth is the best blade material of all, bar none.No the op’s name is Shaihulud. They are an old school 90’s 00’s metalcore band. That’s just one of the lines to one of their popular songs. And also yes I’m aware the name is attached to the dune movie as well.
