- Oct 8, 2024
That's a fine pair ya got there. Help me make up my mind: if I'm forced to order one at a time, should I order the RS or the TM first?
tough one. which blade length makes more sense to ya? go with that oneThat's a fine pair ya got there. Help me make up my mind: if I'm forced to order one at a time, should I order the RS or the TM first?
How dare you make me think?tough one. which blade length makes more sense to ya? go with that one
recon scout and trailm...coating isn't smooth like the O1 steel version I have. think that one was a Teflon type coating. this one feels like some smooth grit to it...but could just be Teflon with some texture in it?More details please. Coating, blade thickness, weight compared to the older versions etc. How’s the sheath fitment?
If I ever get one it will be the RS .How dare you make me think?
Also, I'll probably get the RS first. I've got lots of ~9" blades Bowies from CS.
yep. its hard for me to imagine the Taiwan factory not doing a decent job like they always have. it's nice to see gsm doing some high quality with affordable price points. especially nowadays with high prices everywhere.....If I ever get one it will be the RS .
Already overly supplied with bigger ones .
Assuming these have a good HT etc , great/smart move for GSM to make available more affordable , and tough steel ,versions of these models .
The Cold Steel brand name may actually survive after all !![]()
Exactly !yep. its hard for me to imagine the Taiwan factory not doing a decent job like they always have. it's nice to see gsm doing some high quality with affordable price points. especially nowadays with high prices everywhere.....
that's my hypothesis and reason why sometimes the secure ex doesn't fit right. I know as I've tested same model knives in one sheath. some fit well and some don't. it's a tolerance issue. not obvious to the eye, but enough it can cause secure ex issues with some knives.I will say this: whichever OEM produces Bowies for Cold Steel does not always grind them to a consistent thickness acrossthe various versions. For example, I ordered a custom kydex sheath for my O1 Trail Master (ca. 2018) and the kydex arrived too tight. The sheath maker confirmed that the model he used to mould the sheath was a newer 3V Trail Master which was evidently ground thinner. The flat bevel was thicker on my O1 model than on the 3V model, while everything else had the same profile and dimensions. Fortunately, I loosened up the sheath after 20 minutes in the garage with my heat gun, so all was not lost.
The point is that even if the primary dimensions of the knives are the same across versions/runs, finer details like bevel thickness may vary significantly. So, if you're looking to order kydex then you ought to first confirm which version the maker will use for a mould and consider just sending in your knife for a custom sheath.
Are the 52100 knives exclusives?
They are not exclusives, however they don't appear to be widely distributed. Last I checked they didn't have them listed on Cold Steel's own Web site. They are available, you just need to search them out.
