- Jun 6, 2017
I think Burlap lost its momentum once people spoke out for why they would prefer the Canvas or Linen of Burlap as I think many of the Burlap voters had an expectation of something more like typical micarta.
That is a very poor example of burlap micarta compared to what buck is using. I recomend you look a little closer at Bucks since that is what this is.For those of you who chose burlap micarta, you should check out this thread and re-think your decision (unless you like little voids in your micarta).
https://bladeforums.com/threads/question-about-northwoods-micartas.1653426/
Burlap and denim are poor choices for a micarta base material due to the loose weave; linen and canvas much denser and less air pockets; more base material and less epoxy filler.
JMHDAO
I would expect it to be like the more recent 110 and 501
It’s very hard to find these daysWhat happened to the unicorn horn handle??![]()
g10 isnt might be tougher, it is tougher. cost wise for Buck i doubt is much greater than micarta.So, you're out in the woods and need to build a fire, but since you don't have your Buck Froe with you, you use your new 104 and a chunk of wood to baton a few pieces to start your fire. Which handle material would you be more comfortable with using and confident would come out unscathed; the mostly resin burlap covers, or the mostly canvas CM covers?
I think with the flat ground D-2 steel, we should go with a comparable 'bullet proof' handle material, of which CM is tough to beat. This is a working knife pattern and deserves the most indestructible material for handle covers; G-10 may be tougher, but there is a cost trade off that may be more significant than the durability of the material.
VOTE CANVAS MICARTA!
just my humble dumb-arse opinion. your opinion may vary.
Sure is, jb, this knife will be just fine in either!the only argument here is "I want it", and that is a good enough argument on it's own.![]()
or the burlap micarta or linen micartas etc. theyll all handle like ya said.I can't imagine doing anything with that knife that micarta handle couldn't handle.
