Check out this page on Wikipedia about blade materials.
Country of origin has a lot to do with it.
IMHO, it's not the steel itself, the problem is the Chinese knife industry itself.
Most of us have seen some of the quality knives that have been produced in China for some of the big name knife companies, their demand for quality control and the willingness to pay for it can result in a uniformly good product; conversely, large sectors of the Chinese knife industry are dedicated to producing budget priced items for maximum profit.
Add to this equation a lack government regulation/enforcement and you have the recipe for what we see now in China.
8cr13mov with optimal heat treatment can perform quite well as a knife blade; but, with a cheap HT, or even a cheaper steel labeled as 8cr13mov (or some other well known steel), can be disappointing to a knowledgeable knife user -- leading to the "hate" we see for some of these steels.
In some ways these very practices taint all Chinese products, making even their quality products less desirable to the international buying community.
Just one knife users opinion.
Big Mike
It is a Chinese steel so maybe you should think of it a company rather than a country having to do with it. My customers really like it and I use it a lot.
A. G.
For a high sharpness edge, I've found 8Cr13MoV to be in a dead tie with S30V. This was cutting cardboard, measuring sharpness by push cutting thread on a scale. Byrd Cara Cara and Benchmade Griptillian.
This has been my experience as well. I have a few folders in AUS8 and the 8cr13mov that is my current EDC, the edge lasts much longer than any of the AUS8 blades I own from CRKT and SOG. My brother has a s30v spyderco and he was telling me how much better it is. So we put them both to a large quantity of cardboard. After some cutting his was a bit more sharp. After a huge stack he was sawing to get through while my super cheap China made Schrade retained its working edge. That working edge lasts way longer than AUS8 does and it does not do as much damage to the edge of you hit a staple as AUS8 will get. I used some sand paper laying around and used cardboard to strop it to a razors edge in no time. He required some good amount of time on a dedicated sharpener to get the same edge back.
Does work longer than a super steel and could have kept on doing work but I wanted to show him how quickly that cheap junk steel sharpens up with the most basic method. Yeah his super steel was more sharp after a little bit of work and degrades slower but it keeps on degrading where the 8cr13mov hits a point where the wear slows to a point it will be more sharp after a long period of working.
It's not a gentleman knife steel, it's a working steel and was probably designed to be one. Easy on the bank account but will not give up on you easily and eliminates the bragging rights of needing an expensive sharpening system and extra time to return it to a sharp edge again. Just me but in a working knife from what I've seen the expensive super steel is a failure. That is unless my goal is to show it off to everyone in the latest board meeting and open a package or letters every now and then.
I've seen many mentions of wishing knife manufacturers would stop using it, but I don't get what's so bad about it? Sure it's no supersteel but...it hardens between 58-60hrc, doesn't break easily, sharpens easily, no burr problems, and holds an edge reasonably. Have two knives in it and one I edced for over a year, with moderate use only needed touched up every 1-2 weeks, and I was cutting things like cardboard, foam, tubing and even aluminum wires without chipping/rolling. Only once have I done a full resharpening because it touches up easily. Other knife was a large fixed blade, used it to chop two tree limbs up hatchet style and baton one log and it'd still shave, though not as cleanly. Never broke.
What's so bad about it?
There is a danger of overgeneralizing from limited data and limited test protocols.
We have a thread in which steels are objectively tested for the characteristic that you describe- resistance to dulling from cutting.
http://www.bladeforums.com/forums/s...based-on-Edge-Retention-cutting-5-8-quot-rope
I own and enjoy several knives in 8cr13mov.
You are the first person I have found who claims that 8cr13mov is more abrasion-resistant than S30V, and you may be right - for those two knives.
This may bleed over into the "edge retention vs cutting life" conversation, where geometry is a major player.
That said, I wouldn't take an 8cr13mov blade with me if I had to be somewhere without adequate sharpening tools.
