- Aug 30, 2012
I was just joking, man. I have never said anything serious in the snark thread. With the possible exception of this post.
I think Ray was talking about a BH that dosnt have any Beckersbut wants a 9 again
I started making my kydex sheath today..........cut it up into too small of pieces to usethink paper shredder
I need someone to school me a little bit,
Whats the difference between edge retention and wear resistance?
I hope one of those is for me...
Edge retention is the edge itself and wear resistance is Corrosion resistance maybe? I have no idea, I've wondered that a lot too.
Jerry talks about it a little on his site.
An edge can break down in many ways. One way is for material to wear off through friction. There is very little material on the actual edge, so friction can have an effect rather quickly, pulling little pieces of the metal off here and there. If you have A2 or D2 vs. 1095, your edge (and the rest of the knife) will wear more slowly, and thus hold that edge longer under certain types of use. Of course you can roll, dent, or chip an edge too, none of which would be affected by greater wear resistance.
-Daizee
SO wear resistance is more talking about how the edge holds up to chipping and rolling, and edge retention is more meaning how long it stays sharp in regular cutting when no damage is done?
Or is that backwards... or am i just wrong all over ?
Thank you Daizee for helping explain this!
That's backwards, and exactly the opposite of what I said.
Wear resistance measures how quickly your blade will dull when cutting paper, cardboard, fabric, skin, flesh, etc.
Toughness will measure how your blade responds to impact, torque, etc.
Essentially wear resistance looks at material loss at the micro level, considering the crystal structure of the steel. That includes grain size, carbide distribution, etc. Toughness looks more at the macro level - how the blade responds to larger forces.
The third major component to edge retention is edge geometry, which works along with the steel's internal structure to give it strength to do whatever job you may ask of it.
Looks very pretty but it has as much Becker content as one of my buddy's posts.
