Aye... well... it used to be...![]()
Does anyone use this products to give a satin finish ? This is what professionals use to satin stainless steel.
Good luck, Tyrkon...I think you might need it! Great project!And a thanks to Soup Monger for showing the glass plate setup. I, too, am curious how much cursing and how many bandaids will be required for this!
Sweet! Lots of elbow grease huh?![]()
:grumpy:
Yep! Lots. And all this on a user.
I'm not trying anything on Ban's level. Just trying to clean it up a but and perhaps remove the dimples. Then beat the heck out of it.![]()
Good luck, Looks like your gunna snort some magical INFI dust huh?
Can't wait to see it finished.
Tyrkon,
This one is turning out very nicely. You came up with a very good solution to do the hand sanding :thumbup:
Are you also using that rubber sanding block to do the saber grind? Did you notice any rolling and blending of the saber grind into the flats?
Ban: I am not really trying to get rid of the saber grind. Way too much work by hand. But by removing the grind lines I hope it looks a little more flat. I am just trying to remove the dimples. I will remove as little INFI as possible so as not to mess with the strength of the blade orvoid the Busse warranty.![]()
