- Dec 30, 2008
I love the nice bikes, but hate the little piezo (sp) valve stems.
You mean presta? The thin one that you have to unscrew the little nut and usually use an adapter to a schrader valve?
I just built up a single speed with this Santa Cruz Chameleon frame. So far so good.
Euro bottom bracket? That frame looks sweet!
Presta valves are used on high-pressure tires (many road tires require 120 pounds and more) as the locking cap is less likely to leak air due to road impacts and the narrow stem weakens the already-thin road rims less.
You just need the appropriate pump head; most good pumps have both.
A trick is to unscrew the locknut and the pus in slightly to break the seal before attaching the pump.
Saddles are easily the most-changed original equipment item. Used to be you could go into most bike shops and find a large bin or container full of original-equipment saddles with a sign, "your pick, 5.00".
Most folks look at the skinny-looking road saddles with dismay and can't imagine that they would ever be comfortable. However, if you have a decent pair of shorts, set the saddle angle and position properly,and actually sit on the thing with your "sit bones" like you're supposed to, you will rapidly adapt to the saddle rather than the other way around.
I understand for the "Lance" type rider seat weight is an issue, but why would I want to invest 2 weeks so I can get used to a painful saddle. I put on a larger seat and it was instantly comfortable. I can ride on it for hours without pain. Besides weight, what is the upside to getting used to a skinny seat?
I'll play.Here's some of the herd....
'92 Ciöcc SL
'96 Bianchi Cyclocross
'98 Bellesi
'99 Dirt Works Cannibal
As for material I'll take steel over anything else.
VERY, VERY nice collection... looks like Campy Delta brakes on the Ciocc (love the red & green combo) and Bellesi. Classic!!!!
