Definitely agree 100% with what you are saying. I have done the test with a few other knives of different kinds including a CRK without polishing the washer just for testing sake and the results were the same. I went to polishing the washer with the magic eraser because I'm that anal about trying to remove as much gunk as possible, plus it helps remove any old stubborn grease that did not come off in the brush bath.
I've read thru MOST of these posts...
seems like almost everyone has a lube that has performed reasonably to very well for them...
no lubes that aren't recommended by end line users here, once again if I read correctly and didn't overlook any negative posts...
Also, it appears to me, Finish Line extreme fluro got high praise because of ease of application and cost and AT LEAST similar formulation to CRK grease...
Not advising anyone to stray from CRK specs & recommedations, but does it void your warranty if you do use other lubes?
Lastly, has anyone used a lube that they DEFINATELY WOULD NOT RECOMMEND?
sorry for all the rapid fire questions...but I'm gonna ask em anyways!
If I'm not mistaken, somebody on the MTE forum did a spec analysis of Finishline Extreme Flouro and it was the same as CRK, so if you want an over the counter closest you can get, pretty sure that's it.
Wish I could find that damn thread
[/I][/U][/B]
I only use the CRK grease, but I contacted them a few years back and the way the lady described how the pivot assembly system functions for both lubrication and corrosion resistance, it would probably be unwise to use any type of light oil. Stick to a grease if you don't wish to use the CRK lube.
That old stickied cleaning instruction showed the use of an oil, not the CRK grease, even though the text of the thread (from CRK) recommended the use of their grease.
CRK grease is made from a perfluoropolyether base oil and polytetrafluoroethylene (PTFE) thickener. The CAS number for the base oil is 69991-67-9. If you search on this you find it is 1-Propene, 1,1,2,3,3,3-hexafluoro-, oxidized, polymd, or more simply, perfluoropolymethylisopropyl ether. It (the base oil) is also marketed under the brand name of Fomblin, who makes various lubricants used in vacuum pumps where there is a requirement for a very low vapor pressure.
The Christo-Lube product most commonly thought to be the same as CRK grease is Christo-Lube MCG-111. It has a perfluoropolyether base oil and PTFE. An old (1996) MSDS lists the CAS for the base oil as 69991-61-3, for 1-[difluoro(trifluoromethoxy)methoxy]-1,1,2,2-tetrafluoro-2-(trifluoromethoxy)ethane (Also a Fomblin oil). So it is similar to CRK grease but not identical.
Christo-Lube makes a number of greases, and they probably all vary some in the base oil and the amount of PTFE added. However, the MCG-111 is the only one that I see that is sold in 5 gram tubes. Note that MCG-111 is NSF rated and approved for use in food processing equipment. Both O2Lube and ECL (Engineered Custom Lubricants, a Quaker Chemical Company) say that they manufacture Christo-Lube. ECL says that as a result of a 2013 acquisition, all of Christo-Lubes PFPE lubricants are part of their product portfolio.
The CAS numbers are from older literature, and there is no guarantee that formulations have not changed.
Another grease often mentioned is Finish Line Extreme Fluoro. This grease contains a perfluoropolyalkylether base oil and PTFE. It is made by DuPont. I cant find a CAS number, so I dont know the exact compounds in the -alkyl portion of the molecule. It is likely in the same family as CRK and Christo-Lube.
The bottom line is that these greases may differ due to the exact makeup of the base oil (though they should be quite similar, all being perfluoropolyethers) and the amount and exact physical nature of PTFE added. But I dont expect these differences to be significant. Probably the most notable difference would be in the viscosity, due to differing amounts of PTFE (if any). Having said this, I have only ever used the CRK grease, so I cant state this from experience.
True that's what it says on the website.
However, they used to have cleaning/lube instructions on their site and a sticky in this forum that recommended using their grease alone. Those recommendations have been removed, probably because oil will work and people use to complain about "the special grease you have to buy". That complaint was why they included it with the knife for the last several years.
However, some people complain about the fact that you need to take apart the knife to lubricate it, that's why they now say you can lube it with oil...which you can, it's just not the best. When I first got my sebenza I asked CRK if I can lube it w/o taking it apart and was told I could, but I'd have to use oil, which they said was not as good as their grease. She encouraged me to forget the oil and take it apart and clean/lube about once a year with their grease.
I've tried Finish Line Extreme Fluoro grease, but didn't care for it. Worked well at first but dried into a waxy sludge.
I wish there were a way to buy CRK grease in larger quantities at a lower price. It is my understanding that they simply slap their name on a third-party grease. Does anyone know who makes it?
