- Sep 20, 2015
Keep up the good work there GadgetGeek !a stone
learning type lesson
I'm with you.
Bob is in the details.
anyone ever called "super"
OK . . . looks like the party went home.i have a King 1000
I've heard good things.Nanwia 400 grit Super Ceramic
Agreed. I've reprofiled S110V on the extra coarse DMT and it took no time at all. Fantastic for that.Regardless of your stone picks I would suggest a coarse DMT for grunt work. You will need it unless your time isn't worth anything to you.
Chefs use whet stones, i am starting to also use them.
some really hard stainless steel knives that don't seem to take much sharping
my next go to stone for really hard steels
CS-HD series stones are made of silicon carbide and are designed for the hardest steels (up to 63 HRC). It is advisable to use the CS-HD stone set to sharpen knives made of hard stainless steel or carbon steel. Use of CS-HD stones to sharpen knives made of soft steel is not recommended – this will cause the CS-HD stones to wear at increased rates.
@FortyTwoBlades did you miss my question earlier in this thread? I am hoping for an answer to that.
This should be very helpful to you for understanding the Whet "Water Stones" terms.Oh thank goodness. I was lost there. Some how I have never seen that word in print before (whet with an "h" rather than just wet).
Thanks
I felt like some one who has just gotten off the subway and upon looking around is struck by the fact that suddenly everyone has three legs and two heads.
It wasn't like this yesterday.
It must be Thursday . . . I can never get the hang of Thursdays.
The Superstones are good, and you'll like the 400, I suspect. It is a resin-bonded splash n go. It is the least aggressive 400 stone I have tried, but it also polished the highest, giving you the most refined edge of its category. Although there is much debate about this approach, I'd personally recommend you begin your sharpening sessions with a slurry, as I have found it to produce a more lively cutting response. Then to finish, you can rinse the stone off and hit it with some gentle strokes. The surface will load somewhat; such is the nature of that entire line-up, but you can purchase a 400 grit nagura from Amazon for incredibly cheap. It can be used to simultaneously produce a slurry and clean the surface of your stone. To flatten it, you can simply purchase some low-grit sandpaper, or even rub it on a cinderblock with a little sand. You are within range of incredible results with that stone, and it would suffice as a one stone answer.Am going to try a Nanwia 400 grit Super Ceramic stone, as my next go to stone for really hard steels.
Thanks for your helpful post i received a small nagura stone with one of my King stones and found it very useful, i had to watch a few videos to understand what it was and for what it was used for as everything came written in Japanese with the stone.The Superstones are good, and you'll like the 400, I suspect. It is a resin-bonded splash n go. It is the least aggressive 400 stone I have tried, but it also polished the highest, giving you the most refined edge of its category. Although there is much debate about this approach, I'd personally recommend you begin your sharpening sessions with a slurry, as I have found it to produce a more lively cutting response. Then to finish, you can rinse the stone off and hit it with some gentle strokes. The surface will load somewhat; such is the nature of that entire line-up, but you can purchase a cheap 400 grit nagura from Amazon for incredibly cheap. It can be used to simultaneously produce a slurry and clean the surface of your stone. To flatten it, you can simply purchase some low-grit sandpaper, or even rub it on a cinderblock with a little sand. You are within range of incredible results with that stone, and it would suffice as a one stone answer.
I've started with a 800 grit naniwa as my first bench stone and honestly: it's way nicer than expected. As long as you're not running modern toolsteels, having an 800 as lowest grit is fine (I've even sharpened a ZDP Delica on it a few times and sure it takes some time but it's absolutely doable) and if you transition to a 10k afterwards (as I've done for quite some time) you can get a beautiful, razor sharp edge from just two stones. I wouldn't want to sharpen maxamet that way though...OK . . . looks like the party went home.
. . . if anyone is out there to hear this . . .
My first stone was a King 1,000. Very frustrating experience in that what I really needed to start with was something much more coarse because the edges I had not only needed some reprofiling but were too dull to sharpen the edge on the fine 1000 stone in a timely manner without steepening the sharpening angle and the sharpening angle was already too steep from the factory to cut very well at all or stay sharp very long at all once it got sharp.
I'm a huge fan of very coarse stones to start because one can geeeter done quick then refine as you like. What I mean is you could go back to work with a scrape hair edge right off a 400 grit stone or my fave for a coarse stone a 120 (I like the Shapton Pro 120 Japanese bench stone 10" x 3" water stone if you want specifics). I hear the sweet spot for do all rough stones is 320. I haven't bought one yet. . . . but a 1,000 softish water stone for the first grit on a knife that hasn't been sharpened correctly ever and is seriously dull ? . . . to quote an old coworker : Nah dude, nah.
PS: As far as specifics for the sweet spot coarse stone : Shapton Glass 320 similar size as the Pro above.
PPS : Mandatory Plug : get an Edge Pro.
